94' Touring DYNO PLOT
Old Jan 6, 2003 | 10:47 AM
HeatTreated's Avatar
Hi Powr FD's
Yesterday I hooked up the 7.
got 3 runs in, but the first one had a bad ground the plot read awkward.
*2nd pull in 4th gear is posted top
I only have Intake and N1 exhaust.
(close to stock boost 11-8-10..then drops slowly to 6psi)
** last pull a little hotter and A/F is read on this one. Thinking Im safe enough to install a DP.
-please let me know if pics dont show.
Old Jan 6, 2003 | 11:03 AM
crazysuprakid's Avatar
pics don't show
Old Jan 6, 2003 | 11:47 AM
Hi Powr FD's
crap. yahoo.photos sucks.
233HP & 222 TQ
with a A/F ratio that never goes above 11.5
http://photos.yahoo.com/bc/exhibit76...iew=t&.hires=t
Old Jan 6, 2003 | 12:05 PM
Mahjik's Avatar
Mr. Links
Old Jan 6, 2003 | 12:10 PM
Mahjik's Avatar
Mr. Links
The images were small enough to upload as attactments...
Old Jan 6, 2003 | 12:30 PM
Hi Powr FD's
cool. thanks alot
Old Jan 6, 2003 | 01:24 PM
turbojeff's Avatar
Do it right, do it once
How much boost are you running? How old is the fuel filter? Your car is running pretty lean for those mods, unless you have a PFC or something.
Jeff
Old Jan 6, 2003 | 01:32 PM
Hi Powr FD's
Im stock except for the intake and exhaust
you think thats lean? well the fuel filter does need to be changed.
I just ordered some new plugs (my gas mileage sucks too) but Im gonna try 9's all away around.. and round 2 was to have the filter replaced.. Im thinking of having the dealership change the fuel filter (unless its easier than it looks). thanks for the insight
Old Jan 6, 2003 | 03:12 PM
rynberg's Avatar
Turbojeff is right, you are running lean for those mods (unless the A/F sniffer isn't very accurate). My dyno with a downpipe and cat-back showed an A/F of 10:1 or less from 4500-7500 rpm. This is typical from what I have seen. Replace your fuel filter. I would stick with 7s on the leading plugs, there's no reason to go to 9s with your mods.
If you install a downpipe, watch your boost to make sure you are not spiking or overboosting. For what it's worth, my boost used to drop to 7 psi at 6000 rpm and hold constant until redline. With my new Greddy ProfecB boost controller, it's holding 9 all the way to redline (with a quicker transition to boot).
Old Jan 6, 2003 | 03:42 PM
Hi Powr FD's
lean huh that sux. Ok, I will take the necessary precautions then.. and get the Fuel Filter changed. Mazda wants a crap load for it though! I already ordered the 9's and will try them o see how it runs.
I appreciate it fellas
Old Jan 6, 2003 | 04:16 PM
BoOsTin FD's Avatar
Powered by** Rotary
i thought stock Fd comes with 255 hp. How come you got 233 with intake and Exhaust?
Old Jan 6, 2003 | 04:24 PM
CowsniperRX7's Avatar
Rear Admiral
255 hp at the flywheel. The numbers on the dyno read hp ATW (at the wheels).
Old Jan 6, 2003 | 04:26 PM
kkekeisen's Avatar
255 doesn't account for drivetrain losses...
Old Jan 6, 2003 | 04:51 PM
kwikrx7's Avatar
Most FDs seem to put down 210-225 rwhp stock so those numbers are pretty close to normal - Mazda might screw your car up..unless they have a RX7 or 2 in the bay (i.e. if they work on them alot which is doubtful), take your car to a noteable rotary mechanic. It's well worth it with these cars
Old Jan 6, 2003 | 05:08 PM
Hi Powr FD's
[quote]i thought stock Fd comes with 255 hp. How come you got 233 with intake and Exhaust?[quote] Youve got all those mods and dont know that!? *must have bought yours like that...
Old Jan 6, 2003 | 05:58 PM
BoOsTin FD's Avatar
Powered by** Rotary
I never took mine to the dyno, and i'm not planing on going soon. So i don't know how much hp's do i have. SO I didn't know that, and also i didn't know that dyno only tells rwhp.
[QUOTE]Originally posted by HeatTreated
Old Jan 6, 2003 | 06:33 PM
rynberg's Avatar
You are running a tuneable ECU without ever having been to the dyno? I hope you are not trusting that A/F gauge of yours.... You seriously need to go to a dyno or purchase a wideband to verify that your A/F ratios are safe.
Old Jan 6, 2003 | 08:06 PM
BoOsTin FD's Avatar
Powered by** Rotary
As long as i'm not lean, I'm fine.
Old Jan 6, 2003 | 08:46 PM
rynberg's Avatar
And you know you're not running lean how????? Not trying to bust your *****, just trying to save you from blowing an engine. Going to a dyno shop for 3 runs with a wideband sensor should cost about $60-$70. Spend the money.
Old Jan 7, 2003 | 09:57 AM
Wade's Avatar
Sometimes a cat converter before the a:f meter will throw off the readings, usually it will read leaner than actual. I wouldn't sweat the indicated a:f ratio unless you install the probe before any converters.
Wade
Rotate86
May 18, 2018 02:44 PM
turbojeff
Oct 5, 2015 10:50 AM
