Information poll on water temps
Old Jan 5, 2003 | 09:16 PM
Trexthe3rd's Avatar
After researching and looking at quite a few threads dealing with water temperature, it seems that most people have a working range from 185F(85c)-200F(93.3c) depending on driving (ambient) condition.
After a couple of different coolant related mods, here's what I got:
Ambient temperature: 65F
Stop and go traffic: 175F
Highway speeds < 90mph: 178F
Highway speeds > 90mph: 176F
Repeated hard acceleration: 178F
These temperatures are recorded with the 6psi Evans NPG+ waterless coolant system.
Can everyone post their water temps and operating conditions (if you have a gauge or PFC, etc.) for comparison purposes. Thanks
Old Jan 5, 2003 | 09:27 PM
jeff8932612's Avatar
i usually get around 85C highway and 90+C in stop and go according to my greddy water temp. gauge. That is in Louisiana winter....I dont know what wil happen come summer!
-Jeff
Old Jan 5, 2003 | 09:52 PM
striker's Avatar
hey how is that evans stuff? and how hard is it to change? is it just drain ethyl glycol, flush a few times and and npg?
Old Jan 5, 2003 | 09:55 PM
jr's Avatar
jr
RX-7 Fashion FMIC
Stock Rad with 65/35 coolant/H20 mix
Fan Mod
90F Ambient stop and go traffic - 89C
90F Ambient 65mph cruise - 87C
90F Ambient 0-100mph WOT run @ 14psi - 92C
32F Ambient stop and go traffic - 87C
32F Ambient 65mph cruise - 85C
32F Ambient 0-100mph WOT run @ 14psi - 89C
Old Jan 5, 2003 | 10:40 PM
Trexthe3rd's Avatar
To do the conversion, you'll have to start by a complete drain of the cooling system (both at the radiator and the block), dump the contents of the overflow tank. Fill the system with Sierra or compatible brands of Propylene glycol, no water. Drive the car for a day, drain completely, dump the overflow. Fill with NPG and replace radiator cap (0 or 6 psi).
Here's the link with information on the NPG.
The only draw back is the price on this stuff, it's almost 20 bucks a gallon (you'll need 4).
Old Jan 5, 2003 | 10:56 PM
jr's Avatar
jr
Lot's of good info on Evan's here - https://www.rx7club.com/forum/showth...ighlight=evans Check out the write up on page 5 by Exit13B.
Old Jan 6, 2003 | 10:53 AM
Trexthe3rd's Avatar
There are only two guys that keeps an eye on their water temps? Wouldn't it be better to know your normal operating conditions rather than noticing it after you have problems?
Old Jan 6, 2003 | 11:28 AM
I have Blitz Temperature Gauge and Boost Gauge, plus the PFC. Both meters show different values from the Power FC. I'm thinking the Power FC is off because on my first FD, I had a electronic boost gauge and Power FC and there was a .1 bar difference at all times.
Having said that, on my 1st and my 3rd FD, the PFC indicated 89C the majority of the time. The Blitz Gauge will indicate around 80C.
Old Jan 6, 2003 | 11:32 AM
Shinobi-X's Avatar
Sensory Experience
I usually operate around 180F, but I also always drive with my fans on.
Old Jan 6, 2003 | 12:08 PM
Trexthe3rd's Avatar
What type of cooling mods have you guys done?
Old Jan 6, 2003 | 03:13 PM
gotorx7's Avatar
The 7 can't lose!
Ditto... What temp do you run at without the fans?
Old Jan 6, 2003 | 05:08 PM
rx7ofmine's Avatar
I thought most people that did the fan mod run at 185 to 190 range? Slightly higher in stop and go.
Old Jan 6, 2003 | 05:15 PM
Shinobi-X's Avatar
Sensory Experience
Only mods I have are in my sig.
I don't know, as I usually turn them on after the car warms to about 160ish. Actually, I found out the hard way, and thats why I always drive with them on now. My friend was sitting in the passenger seat one day, and alerted me to the fact that my temp guage was reading 250F I later found out that my coolant light didn't come on, and I was leaking coolant from somwhere. So now I always keep a careful eye on my temp. guage and drive with the fans on.
I've never had to use the secondary switch, as I stay close to 180F at all times. I have to wait until summer to see how the heat affects the car...though I know by then I'll have more cooling mods done...
Old Jan 6, 2003 | 05:59 PM
SoCalLove's Avatar
Shinobi, do you keep your fans on on freeway driving as well. I just turn mine on as soon as I get off the freeway. I read somewhere awhile ago that usually speeds above 30-40mph and you should leave the fans off?
I don't have a temp gauge yet, btw.
Old Jan 6, 2003 | 06:10 PM
Shinobi-X's Avatar
Sensory Experience
I've never heard that rule before, but anytime I get on the throttle, I keep the fans on, so yeah, for the most part I keep them on when I get on the highway. I've actually been as low as 150F though when it was cold out, so I usually turn them off if the temp. gets that low. In general, I try to keep the car as close as possible to 180F. Oh, and GET A TEMP GUAUGE as soon as possible. It saved my car once, and it's HIGHLY recommended...that and a boost guage if you don't have one.
Old Jan 6, 2003 | 09:06 PM
Whats the formula to convert from Farenheit to Celsius? Thanks.
-Jeff
Old Jan 6, 2003 | 09:40 PM
jr's Avatar
jr
F=(1.8xC)+32
C=(F-32)/1.8
Old Jan 7, 2003 | 12:32 AM
180-195 F
I put the 90C fan switch on the thermostat housing so it turns fan on low when ever it reach 90c.it just like automatic fan mode.I know you guys with PFC can turn the fan any temp.but I still using EFI PMS
DP,intake,street ported motor.
Old Jan 7, 2003 | 02:12 AM
skunks's Avatar
I'm a CF and poop smith
180 F. all the time except when i go up hill (30-35degree incline) on full boost for about 5 mins, then it gets up to 200 F. but after i slow down, it drops back to 180 F. in about 20 secs
Old Jan 8, 2003 | 03:00 PM
Mine goes between ~180F on highway cruise to ~210F on stop and go traffic with driving lights on. Without the driving lights on the fan won't kick in until ~230, where the OEM temp gauge needle starts going north.
I have the following:
Fluidyne radiator
CWR dual oil coolers
Vented hood.
Old Jan 8, 2003 | 03:32 PM
j9fd3s's Avatar
Community Builder
mine will run 83-85c on the freeway, if its hot outside around town it will creep into the lower 90's c. if i beat on it the temps will get up to the upper 90's c. the only mod is a mazdacomp radiator and 70/30 water coolant mix
mike
Old Jan 8, 2003 | 05:41 PM
what temps should you start becoming alert too?...like i have seen a little over 100C once when I was hardly moving in traffic. When should i become concerned? The temp always goes back down to my norm of about 80C once I started moving again. Thanks.
-Jeff
Old Jan 8, 2003 | 06:17 PM
Fritz Flynn's Avatar
All out Track Freak!
I think the fans come on around 220f and go to medium at 225f but not for sure. Basically don't want to see temps at or above 235 for long During the summer at the track I run 102c and cooler months 93c. 100c and your fans won't even come on so thats nothing to worry about.
Old Jan 8, 2003 | 07:31 PM
rynberg's Avatar
I finally got my water and oil temp gauges (Defi link series -- full post w/pics coming) installed over X-mas.
I have a downpipe, cat-back, and completely stock 65k cooling system with 50/50 (too much coolant, I know).
With ambient temps in the low 60s, I am getting:
stop and go traffic: 210 F
normal city driving (35-45 mph): 190 F
highway: 175-180 F
The temps will rise quickly when going full boost but drop back down again very quickly. BTW, turning on the A/C to setting 3 while driving around town quickly drops temps to 190 or less. At idling, A/C will lower temps to below 180.
My oil temps vary much more, anywhere from 160 to 220 F, and don't seem to always correlate with the water temps.
Old Jan 8, 2003 | 09:26 PM
adam c's Avatar
Cheap Bastard
On a 60 degree day, my car will run 180 to 190 if it is on the freeway. Just sitting at idle in my garage, on a 50 degree night, it will go up to 220 or more. Stop and go traffic will give me high temps also.
I just put in a Fluidyne radiator to help this issue.
