Has anyone ever installed the gt35/40 themselves.
Has anyone installed it themselves and have any pointers to give.How hard is it to put a new secondary fuel rail on.You do not have to pull the motor correct.
any help is appreciated.Thanks
If your current setup is a twin setup, expect to spend 3 - 4 hours taking things apart pulling stuff that you don't need anymore out (rats nest, stock manifold, stock turbo, etc). Then expect another 3 - 4hours to put the new fuel rail, fpr, connecting hoses, resistors (assuming you are going to 1600cc) and turbo assembly, dp, manifold, WG in. Maybe longer...The process went very smooth for me (us @ the RX7 store) for the first GT35/40 install we did (mine). But have had experience with other single kits in the past...
k
k
k
k
Note: Nocab is a EE and Zayvier is a wiz with tools. So your results could vary.
Trending Topics
Drive it down, we will install it for you. www.rx7store.net
Then you can enjoy the weekend driving around with 10 rx7 around town.
nocab
I have the same mods as you and am ordering the gt35/40. Do you have a map available from your car at 15.5 psi that you could share. I hope it would help me to get in the ballpark. I am in western Canada and no one knows the datalogit or rotaries on a dyno here so i hope to get the basic tune close and have them fine tune it on the dyno. Also curious what fuel pressure you run.
Thanks
Thanks
24seven_dada
20
Nov 10, 2018 12:03 PM
