Changing the spark plugs
Old Jan 3, 2003 | 11:19 PM
SWAT81's Avatar
8AN5H33
Exclamation Changing the spark plugs
Does anyone know when you change the spark plugs and remove the manifolds the gaskets are reusable or do I have to replace them?
Old Jan 3, 2003 | 11:45 PM
oakridgerx7's Avatar
you dont have to remove anything to change the spark plugs. Just go in from the side, you should have them changed out in about 15 mins.
Old Jan 3, 2003 | 11:49 PM
GoRacer's Avatar
Speed Mach Go Go Go
Underneath the featured car (top/right), click on the word "search" and use the key word "spark plug" and then tell it to search in 3rd gen section.
I beleive (guess)the regular coppers can last 5-15k mi and the platinums can last 15-25k mi. They can be changed from underneath the car and no gaskets need to be removed.
Old Jan 4, 2003 | 04:41 AM
Mercury's Avatar
How old are the wires?? How many miles do you have one them?
Old Jan 4, 2003 | 05:02 AM
Make sure you connect the wires correctly. They are labled T1, T2, L1, L1.
You should be fine using Trailing 9.5 spark plugs all around.
personally its a pain getting to the spark plugs. It might be easier for you if your remove your throttle body.
Old Jan 4, 2003 | 06:57 AM
salamander's Avatar
You can do the spark plugs from underneath very easily. Jack up the front, driver's side part of the car. Slide under with a 21 mm deep well socket (may need an extension) and have at it. Takes about 15-20 minutes.
I replace mine every 10,000 miles.
Old Jan 4, 2003 | 07:37 AM
skunks's Avatar
I'm a CF and poop smith
it should not be that hard to remove them with out taking off the uim, I personnaly did it about 30-40 times in about 3 days (tried to unflood my unflooded engine, long story hehe)
just grab a sparkplug wrench and go at it.
BTW: if the gaskets are not ripped, your fine (just reuse them)!
Old Jan 4, 2003 | 07:44 AM
rxrotary2_7's Avatar
Old Jan 4, 2003 | 10:37 AM
93BlackFD's Avatar
built my own engine
is there a document around that explains the leading/trailing thing...my brother asked me, i couldn't explain...felt stupid
Old Jan 4, 2003 | 10:40 AM
what dont you understand? why they are there?
Old Jan 4, 2003 | 10:42 AM
maybe this will help. it sounds like it is going to be WAY over your head if you dont understand why they are there....but have a look. https://www.rx7club.com/forum/showth...&threadid=8807
Old Jan 4, 2003 | 05:40 PM
Rated R1's Avatar
Oji San
OK he is not changing the wires there is absolutely no reason he would have to remove the throttle body. Shouldn't have to remove the UIM. WTF is that? Just change one plug at a time from underneath that way you won't croos any of the wires. Also make sure you use some anti-sieze on the plug threads. It also helps to put some dielectric grease on the plug too.
Old Jan 5, 2003 | 06:40 AM
salamander's Avatar
Also, there are two plugs per rotor, with one above the other.
Trailing = Top
Leading = Lower
Old Jan 21, 2003 | 12:23 AM
SWAT81's Avatar
8AN5H33
Well apparently I decided to change the wires as well and hell! That was such a tedious job! Had to remove the manifold, throttle body, and all these hoses just to get this one wire in~! Sheesh~ such a pain in the *** to get this thing done~ Oh yea and the gaskets weren't reusable since they broke while taking the throttle body off. ^_~
Old Jan 21, 2003 | 08:25 AM
paw140's Avatar
You didn't remove the UIM to change the wires, did you? Because you don't have to... just the throttle body.
Old Jan 21, 2003 | 08:51 AM
RonKMiller's Avatar
Blow up or win
Dood, next time, read how to do it before you start breaking things.
If you have anything other than dainty little hands with skinny fingers, do it from underneath. Easy. Takes 10 minutes. Just make SURE you use jack stands - right?
Old Jan 21, 2003 | 08:59 AM
Rated R1's Avatar
Oji San
10 minutes to change the plug wires. You are a rotary god there Ron.
Old Jan 21, 2003 | 09:32 AM
paw140's Avatar
I think he was talking about the plugs.
Old Jan 21, 2003 | 09:57 AM
maxpesce's Avatar
Ex fd *****
Takes More than 10 min but I change the plugs & wires from the TOP w/o removing the TB, just the Intake elbow!
Old Jan 21, 2003 | 10:00 AM
RonKMiller's Avatar
Blow up or win
Actualy the wires are quicker than that - once you have the throttle body elbow off. I have a friend that can change them with the throttle body elbow ON, but he's about 5'4" tall and could probably crawl inside the engine bay with the hood down.
I need a mini-me!
Old Jan 21, 2003 | 10:08 AM
paw140's Avatar
I don't see how it is possible, no matter how small your hands are, to change the wires without removing the TB, elbow, and oil filler tube. The filler tube is completely in the way of sliding one of the wires off. That's my experience, anyway.
Old Jan 21, 2003 | 10:18 AM
Rated R1's Avatar
Oji San
Yeah I gotta get me one of those mini me's.
and a sugar mama
Old Jan 21, 2003 | 10:48 AM
SWAT81's Avatar
8AN5H33
I was actually changing the plugs and the wires, the wires were a pain in the *** to change though, ended having to buy a new gasket for the throttle body.
Old Feb 1, 2003 | 02:34 PM
Kaotic Dan's Avatar
Well i'm new to rotaries, but I just changed my spark plugs in 5 minutes. I reached down from the top. I don't have A/C or Powersteering though, is that what made the difference? Wasn't hard.
Old Feb 1, 2003 | 03:16 PM
CYM TKT's Avatar
hey, your car is on fire!
I just remove the intake elbow and I can get them fine from above the car. takes me like 15 mins total now.
now for the wires, thats a PITA and I had to remove the throttlebody.
