ported
Old Aug 9, 2001 | 09:34 PM
suganuma's Avatar
no
ported
when your engine is ported....street ported in this case, should you see more or less vacuum.
meaning how can you tell how wildly or mildly ported your engine is by looking at vacuum numbers??
does a port pull MORE vacuum? ive always thought so but wanted to make sure i had the right info
i have a street port and am usually pulling about 19 on the vacuum gauge @750 rpm
what kind of numbers do yall see on your motors and tell me if youre ported or not
thanks
Old Aug 9, 2001 | 09:47 PM
RXJJang's Avatar
under construction...
Here is some info///
I got this from Scuderia Ciriani's site.
http://www.scuderiaciriani.com/rx7/boost_test.html
__________________________________________________ __
Date: Thu, 29 Jun 2000 16:36:11 -0700 (PDT)
> My car idles at about 750 RPMs. Is the vacuum reading a sign of how
> aggressive the porting is?
Yes.
Normal stock motor will show 18" or better.
Mildly ported motors show 14"-16".
Heavily ported motors can go down to 10"-12".
I myself have a street port and pull around 14" vacuum @ idle.
Hope this helps
iamsisyphus
Sep 27, 2015 01:42 PM
josef 91 vert
14
Sep 17, 2015 09:22 PM
