doest go above 5 mph??
Old Jan 2, 2003 | 01:02 PM
nokiaman's Avatar
I have a very weird problem wid my car. The car starts fine but it doesnt go above 5 mph even if i press the accelerator full. The pipe going from intercooler to throttle body contracts when i press the accelerator. Any idea what could be wrong??
Old Jan 2, 2003 | 01:06 PM
zyounker's Avatar
root
Need a little more description of what is happening..
What do you mean contracts? like the plastic pipe colapses? or the coupler does?
if something is closeing up, there is something probably wrong with it..
-Zach
Old Jan 2, 2003 | 01:10 PM
nokiaman's Avatar
No the coupler(which i suppose is the soft part) contracts when i press the accelerator even in neutral
Old Jan 2, 2003 | 01:17 PM
jr's Avatar
jr
Sounds like you've got a serious restriction in the intake. Is the car stock or modded? I'd pull the intake and associated piping and look in there for something stuck. If your running an aftermarket intake/filter check to see if didn't get sucked up in there. If everything on the intake side is clear then pull the upper part of the Y pipe and TB elbow and check in there. Good luck.
zyounker's Avatar
root
Well, the 2 pipes should be almost flush with each other, the coupler should not really gap the space. just seal it..
Hope that makes sense, you probably just need to move it around a little..
-Zach
Old Jan 2, 2003 | 01:23 PM
nokiaman's Avatar
Do u think its because of any pipe leaking? therefore the car is not gettin any power at all? lets say theres a leak and the boost is leaking, but does it mean that the car doesnt run above 5 mph?
Old Jan 2, 2003 | 01:30 PM
zyounker's Avatar
root
Not if it is colapsing..
It is either a restriction, or the coupler is on wrong, and when it colapses it causes the restriction.
-Zach
Old Jan 2, 2003 | 01:34 PM
nokiaman's Avatar
what do u mean by restriction?
Old Jan 2, 2003 | 01:57 PM
GsrSol's Avatar
Z06 powered FD
Like you sucked up a bag and it's covering the intake. It's trying to suck but it can't, something is restricting it.
Old Jan 2, 2003 | 02:00 PM
zyounker's Avatar
root
restriction: some sort of blockage. Something is preventing the engine from getting air.. The intake is plugged up somewhere.
-Zach
Old Jan 2, 2003 | 02:31 PM
jr's Avatar
jr
Take a straw, put one end in your mouth and cover the other end with your finger, now suck real hard. See that? Understand what's happening now?
Old Jan 2, 2003 | 07:21 PM
Air-Rex's Avatar
If you have a boost/vacume gauge, I'd be real curious what it's reading when this happens.
Eric
Old Jan 3, 2003 | 01:36 AM
nokiaman's Avatar
The reading is normal when the car is in neutral i.e 500mm/hg. However it doesnt go above this even if i press the accelerator full. I also checked the intakes and it seems normal and nothing is blocking or restricting it.
Old Jan 3, 2003 | 01:41 AM
skunks's Avatar
I'm a CF and poop smith
obviously something is blocking your intake! Perhaps you sucked in a small animal/small child or something , double check all your intake hoses.
TrboMike
NE RX-7 Forum
Sep 28, 2015 09:40 PM
Thor 18
Sep 28, 2015 07:35 PM
Casual_John
Canadian Forum
Sep 26, 2015 01:47 PM
The1Sun
Sep 18, 2015 07:13 PM
The1Sun
Sep 15, 2015 04:45 PM
