fuel line questions
Old Jan 1, 2003 | 07:09 PM
hornbm's Avatar
FD > FB > FC
fuel line questions
As many of you may know, I am putting in a complete stock setup, 89 N/A motor.
Because my car is an 85 GS, its carbed and not EFI.
My question is there anything I need to do to the fuel lines because of the substantial fuel pressure of EFI?
I saw directfreaks setup, and I dont want to put that much money into the fuel lines....... yet.
Old Jan 1, 2003 | 08:23 PM
JIMMY54's Avatar
GSL-SE PRO
Im not an expert but im pretty sure you must put bigger fuel lines and a different fuel tank
Old Jan 1, 2003 | 08:30 PM
Directfreak's Avatar
I am a Jeeper Now.
Re: fuel line questions
You don;t have to run braided fuel lines. I am just overdoing it, as usual. Even Mike-P used a stock fuel pick-up for his high-HP Cosmo.
If your running a stock 89 engine, I am pretty sure you can get away with the STOCK Lines. Just make sure you get good EFI fuel pump. A stock GSL-SE pump could work too.
The only recommendation I would give you is, to consider your long term goals, so you don't spend money on parts you're going to have to upgrade again later - if you're going to go crazy.
Old Jan 1, 2003 | 09:40 PM
RotorMotorDriver's Avatar
Seven Is Coming
I saw 25 foot rolls of alluminum fuel line in Summits catalog for about $20 a roll. I thought aobut using that stuff when I replace all my crap from the tank to my carb. Anyone see why not to?
~T.J.
Old Jan 1, 2003 | 11:35 PM
hornbm's Avatar
FD > FB > FC
so the stock lines will work for the time being?
I had this horrible thought of turning the key for th first time and watching the lines explode off the car, shooting gasoline everywhere.
Directfreak I trust your judgement, so I guess I'll be fine for the time being.
I should have the car running at the end of the month. I'll post pics when its done AND i'll post a write up on how to deal with the 89 wiring harness. It'll be really complete as I have my buddies from the electronics class next door helping me on it.
There's no reason why someone should have to have the same headache I'm having.
bb6guy
Old School and Other Rotary
Oct 1, 2018 08:07 AM
bb6guy
Aug 12, 2015 03:29 PM
