rear defroster fix
Old Dec 29, 2002 | 07:08 AM
xlversatilelx's Avatar
rear defroster fix
my rear defrost wires are not attached to the windows how can i do a quick fix on this? would it be possible if i were just to solder it back on to the window
Old Dec 29, 2002 | 08:23 AM
85RX7GS's Avatar
Solder them back to the window. Click this link Defroster and scroll down to the defroster section.
Old Dec 29, 2002 | 09:49 AM
MIKE-P-28's Avatar
Driven a turbo FB lately?
You can solder it back to the glass if theres anything to solder too, cross your fingers and hope there is , other wise theres really nothing you can do
Old Dec 29, 2002 | 03:37 PM
MarkPerez's Avatar
Tennis, anyone
As long as there are the 2 strips where the wires went.
on the window your ok to solder. if there are no connectors left on the window, you can use just wire connectors, the 2 piece kind, one end solder to the window, the other, to the coil wires. I would say solder to the window first. use at least a 100 watt soldering iron.(because the glass acts like a big heat sink) all pieces,, file,, to clean metal, it'll stick better that way.
and use a 50/50 or 60/40 solder and water base flux.
Old Dec 29, 2002 | 08:25 PM
on the coil wires theres a little like metal plate attached like a little square? would i still be possible to solder it back to the window ??
Old Dec 29, 2002 | 08:39 PM
85RX7GS's Avatar
Yes
Old Dec 29, 2002 | 08:40 PM
MarkPerez's Avatar
Tennis, anyone
That my friend would depend on how well you can solder. Sure you could,trying to solder in that area is a pain in the *** though (with the coil wire attached) use some hymo's to hold the piece. ( gets hot,real fast ) if you use your fingers, file all pieces, ,,, same gig.
Th0m4s
Feb 26, 2019 02:04 AM
tsmith94FD
Aug 16, 2015 05:41 PM
