stalling
Old Aug 9, 2001 | 07:58 AM
girlfriend's Avatar
stalling
my 86 gxl is stalling out in first....The idle is ..well it won't idle..It has been really hot the last 2 days. If anyone knows....
It's kind of embarrassing ....REd lights and traffic jams are not my friends right now :-(
Old Aug 9, 2001 | 10:28 AM
ZachSpazz's Avatar
I wish I had a posse...
Adjust your idle by using the adjust. screw on the top of the throttle body. It should be under a little rubber cap, have someone look at the tach and try to get around 75-800 RPM with a completely warmed up engine.
Old Aug 9, 2001 | 12:00 PM
girlfriend's Avatar
I tried the adjustment screw but am finding it somewhat difficult as it just won't idle steady at all .
Old Aug 9, 2001 | 12:47 PM
rx74ever's Avatar
check your tps test it with the light method you should find if you do a search on the site it could be bad or just not tuned properly or if you have an ohm meter you can use that to test it should be at 1.00 with ground once you adjust it should idle fine
toplessFC3Sman
Mar 20, 2018 01:54 PM
Einheri
Oct 7, 2015 12:23 PM
xXBrendanXx
Power FC Forum
Sep 17, 2015 10:10 AM
REX7&Z32TT
Sep 9, 2015 05:16 AM
Steven_McKinley
Sep 5, 2015 10:48 AM
