setting up turbo efi fuel system. need help
Old Dec 28, 2002 | 03:54 PM
82streetracer's Avatar
8/1 Building/Drive Ratio
Okay,
got the rails
got the injectors
got the regulator
got all the an lines and fitting and a filter.
now for the pump, I have been looking at bosch and walbro.
but, there all intank pumps,
I have the stock tank in my 82 right now but Im going to install a SE tank when I find one.
anyhoo, could this pump be made to work externally, maybe if a low pressure carb pump was before it.
Old Dec 28, 2002 | 03:59 PM
MIKE-P-28's Avatar
Driven a turbo FB lately?
bullshit, they make external pumps, www.horsepowerinabox.com
email tim
ps all prices in aussie dollars, dived by 2 to get the us total, and can you say cheap ?
Old Dec 28, 2002 | 04:12 PM
excellent, have you ordered from them, how much is shipping to the states? there is alot of really cheap stuff on there.
Old Dec 28, 2002 | 04:14 PM
wow, a haltech e6k for $1000 full termed with a o2 and everything, daaaaammmmmmnnnnn
Old Dec 28, 2002 | 04:49 PM
Directfreak's Avatar
I am a Jeeper Now.
Re: setting up turbo efi fuel system. need help
Originally posted by 82streetracer
Okay,
got the rails
got the injectors
got the regulator
What rails? Stock? Are you planning to weld AN fittings to them? If so double check, because some don't take welding too well.
Old Dec 28, 2002 | 05:02 PM
Eville140's Avatar
Alot of us ****-ton guys get our pumps from here.
http://www.autoperformanceengineering.com/
Nice thing about his externals (walbro's) is that you can also order damn near any type of inlet/outlets you want on them.
Later
Randy
Old Dec 28, 2002 | 06:46 PM
rx7passion's Avatar
get teh bosch 044 and you wont be sorry. hell of a pump used to have one
Old Dec 28, 2002 | 07:22 PM
rxtasy3's Avatar
nope, multiply by .561
Old Dec 28, 2002 | 07:44 PM
setzep's Avatar
If I were to do it all over again I'd do a surge tank set up.
Old Dec 28, 2002 | 08:06 PM
i dont beleive a surge tank is necessary in my application.
I am not putting down huge power, this is a daily driver.
I modeled my setup exactly the one on fc3s-pro.com
http://fc3s-pro.com/TECH/MODS/FUEL/prail.jpg
I have this setup exactly,
glsse injectors primary, 1600 secondary rails with bosch injectors.
all I need is a pump.
Old Dec 28, 2002 | 08:17 PM
Zulu's Avatar
speaking of pumps ... I'm gonna go ahead and go a bit off topic here :p
can the stock gsl-se fuel pump deliver enough fuel to run a 75 wet shot along with close to maxxing the stock injectors?
k back on topic...
Old Dec 28, 2002 | 08:28 PM
i doute it.
Old Dec 28, 2002 | 10:28 PM
rx7passion's Avatar
yeah that is a good setup for the fuel system. i did the same thing i try and find the pictures i had...
Old Dec 29, 2002 | 12:31 PM
setzep's Avatar
The only reason I would do a surge tank is to eliminate the possibility of the engine being starved of fuel. I would just hate to see what happens when your at 15psi full throttle and your fuel pump takes a gulp of air due to your tank being 1/4 full while your taking a sharp turn I'm just throwing out the idea thats all. But the way you have the fuel lines run to the rails is probably the best way. If I make my own rails I'll do the same.
-Cam
Engine stand ready
Aug 14, 2015 10:26 PM
KAL797
Test Area 51
Aug 11, 2015 03:47 PM
