Sensor on bottom of radiator. What does it sense?
Old Dec 27, 2002 | 03:30 PM
Maguire's Avatar
Born 2 Brap
Basically, what does it do? does it really work? Whats it called? do i need it for anything? Where could i find one? I thought i saw it in VB, but i misplaced my catalog.
The one on top is just a level sensor for the idiot light right?
Thanks guys.
Old Dec 27, 2002 | 04:03 PM
gamble302's Avatar
roadkill hats rock
thats a damn good question
yeah the oen on top is for the idiot ligh, and the temp sensor is below the oil filter. i checked the haynes manual and it doesnt mention disconnecting anything besides the low coolant sensor. hmmm
i dunno what it is, i took it out of my rexes with no ill effects though
Old Dec 27, 2002 | 04:12 PM
inittab's Avatar
I read your email
I think it's to sense when it's warm enough to pop the choke back in but I could be wrong.
Old Dec 27, 2002 | 04:13 PM
gamble302's Avatar
roadkill hats rock
could be, but i thought the sensor on the water pump was for that?
Old Dec 27, 2002 | 04:45 PM
inittab's Avatar
I read your email
Just looked it up and sure enough the sensor on the water pump is for the choke and the hot start assist. The sensor on the bottom of the radiator is for the emission control system. It sends a signal to the ECU when the radiator temperature is above 59 degrees.
Old Dec 28, 2002 | 12:53 PM
Sterling's Avatar
Nikki-Modder Rex-Rodder
Great job!
Four more wires I can yank out!
(Or 2 more temp sensors I can figure out something neat to do with. )
Old Dec 28, 2002 | 04:52 PM
MIKE-P-28's Avatar
Driven a turbo FB lately?
The sensor thats right next to water inlet neck affects the choke ... I know this for a fact, because i had to replace mine once, choke wouldnt stay out or go back in, i forget? But I rememebr the ****** was expensive
But thats what it was..
Old Dec 29, 2002 | 01:59 AM
MRGSL-SE's Avatar
ROTOR THAT PUSSY BITCH
It does the same thing on a GSL-SE, right?
I know what its called, its a Coolant Temp Switch, the Relief Solenoid controls it or something... for the GSL-SE,
The One thats on the water pump is the Coolant Temp Sensor, they're expensive.
Anybody know how to check it, if its working
Old Dec 29, 2002 | 02:02 AM
MRGSL-SE's Avatar
Old Dec 29, 2002 | 02:21 AM
680RWHP12A's Avatar
the one at the bottom of the rad. is useless!!! throw away
Old Dec 29, 2002 | 02:24 AM
gamble302's Avatar
roadkill hats rock
already did
sheeeeesh
Old Dec 29, 2002 | 12:39 PM
Maguire's Avatar
Born 2 Brap
Cool, cause mine got busted when it got pushed into the fan. So looks like another hole for a bolt and some silicone. Thanks guys!
Old Dec 29, 2002 | 04:42 PM
85RX7GS's Avatar
Re: Sensor on bottom of radiator. What does it sense?
Yes it is.
imitek
24
Dec 1, 2015 03:35 PM
