Yet another Guage Question
Old Dec 26, 2002 | 09:11 PM
hey i got a problem... i just did a dash pull and put in the new S/R Motorsport guages... My RPM guage is now way off... At idle it says that a i am at 0 RPM's... What can be wrong?? thanks, Rotary-Rex
Old Dec 26, 2002 | 09:19 PM
bcty's Avatar
Boost This!
does it move when u rev it up? did u connect the things properly in the back? whats your speedo read?
Old Dec 26, 2002 | 10:33 PM
82transam's Avatar
Never Follow
If it moves properly then you probaby put the needle on wrong or something along those lines.
Old Dec 26, 2002 | 10:35 PM
AdrenalifeRX7's Avatar
Are you gonna shift?!
sometimes the needle is put on in the wrong spot...it has to be just right to be calibrated right or else the magnetics will read the tach speed wrong.
Old Dec 27, 2002 | 01:58 AM
ok the speedo gear seems to be fine...when i rev the car the rpm guage works.. but it is off.. When the car is shut off, the needle sire about a half an inch below the 0 mark... I never took the needle off, i just slipped the new guage faces over it, is it possible it got turned or something? Thanks all Rotary-Rex
Old Dec 27, 2002 | 02:12 AM
Adsy01's Avatar
ACBron Motorsport
i would be thinking that is what has happened
_Tones_
May 25, 2021 05:37 AM
Nosferatu
Sep 5, 2015 02:13 PM
gabescanlon
Sep 5, 2015 12:09 AM
