I need a decent MAP (E6K)
Old Dec 24, 2002 | 12:39 PM
Rx7-AIII's Avatar
Hi and Merry Christmas.
Seen as its Christmas please can someone help out.
I have a GT3540 set-up (0.7/0.84) on my 3rd gen. 550 and 1600cc injectors, standard engine with IC, Intake, fuel mods etc. Car is run with a Haltech E6K.
My map is bad and the car runs very rough. I have spent a fair bit of time trying to improve things but am not getting very far. The original base map was for a T-66 and has been modified.
Please can someone with a similar set-up share a map with me. I will send my map to anyone interested in looking at it.
Thanks and Merry Christmas
Martin
Old Dec 24, 2002 | 07:04 PM
MIKE-P-28's Avatar
Driven a turbo FB lately?
Martin, look at www.ricemobile.net and see if theres a map on there that can help you... I had the same problem as you, I eventually ended up doing it myself I got it to ran half decent now... But took shitloads of time!!!
Good luck mate
Old Dec 25, 2002 | 03:53 AM
Rx7-AIII's Avatar
Thats where the T-66 map came from. I have been re reading some Hitman notes on timing set-up. I am wondering if its still out and also not helping. The map its self is still not good though (it probably was better before I started playing with it).
I will live in hope of a better map.
Old Dec 25, 2002 | 12:55 PM
Bridgeported's Avatar
If you make a post in the Haltech forum, you might get some good replies.
Merry Christmas.
Old Dec 25, 2002 | 01:15 PM
Silver7's Avatar
The hitman has some maps for a 60-1 that should work for you.
Old Dec 26, 2002 | 04:35 PM
I have a great map, w/similar mods for 15psi, Only I have 720 primaries, and a SX RRFPR. The car runs better than stock in ALL conditions. The Turbo is a TO4S, making high 300s at 15psi. Perhaps hitman can help with the fuel map adjustment. Post your email and I'll send it to you. As always use at your own risk. Carl Byck
Old Dec 26, 2002 | 06:55 PM
Rx7-AIII's Avatar
Hi, Thanks
I would appreciate looking at it. At least I can compare values in the maps if nothing more. The only maps available to look at are the few on Ricemobiles web site!
Many thanks
Martin
sintler@lineone.net
Old Dec 27, 2002 | 01:08 AM
Rx7-AIII's Avatar
The map arrived, thanks. I will have a look at it later on.
nismorx7
Power FC Forum
Oct 1, 2015 10:36 AM
killerrx710
Sep 28, 2015 09:13 AM
killerrx710
Sep 24, 2015 10:57 PM
