Metric Oil Fittings
Metric Oil Fittings
I got my 2nd gen oil cooler, but I'm in need of the four fittings (two on engine and two on the oil cooler). Does anyone know the correct metric sizes? Mazdatrix has all this AN stuff, but they don't list the size of the fittings
The two that go on the oil cooler are 18mm x 1.5mm, the one on the front cover will be a 16mm x 1.5mm, and the one on the rear plate will be a 18mm x 1.5mm...I think. Those all need to adapt to whatever size -AN fitting you are using (-10?).
~T.J.
~T.J.
