Marquis De Sade designed airbox
Old Dec 22, 2002 | 11:02 PM
BLKTOPTRVL's Avatar
After removing and installing the airbox and the upper and lower radiator hoses I am convinced that I should buy an aftermarket unit if I ever need to remove the box again.
After breaking most of the electrical connectors during this job I am convinced that the underhood heat is hardening everything prematurly.
Has anyone found an intake shroud that will mate to a MazdaSpeed hood to vent extra heat in addition to providing intake charge cooling?
Old Dec 23, 2002 | 12:23 AM
adam c's Avatar
Cheap Bastard
Electrical connectors? The airbox doesn't have any electrical connectors.
The high temps under the hood can't be good for anything under there. You should do the fan mod on Steve Cirians website. It runs the fans for 10 minutes after you shut down the car. It helps a lot.
Adam
Old Dec 23, 2002 | 12:12 PM
BLKTOPTRVL's Avatar
The Hose and Airbox job were part of a larger operation in which I changed the EGR Valve, Hoses, Air Cleaner Element, and Spark Plugs.
Old Dec 23, 2002 | 01:10 PM
jpandes's Avatar
Yup, those stock airbox hose clamps are pain in the *** to deal with.
Old Dec 23, 2002 | 05:24 PM
adam c's Avatar
Cheap Bastard
I like the stock spring clamps. Just grab them with a big channel lock, slide them down a bit, and it's done. No screw that you have to turn 10 or 15 rotations.
Old Dec 23, 2002 | 06:17 PM
Kento's Avatar
2/4 wheel cornering fiend
I hate the stock spring clamps. I've replaced them with easier, lighter (OK, so it's a miniscule amount) hose clamps. Just get a decent ratchet and socket, twist your wrist a few times, and it's done. No spring clamp that wants to jump out of the channel locks if you're not careful, or requires that you have hands the size of Andre the Giant to maneuver.
Old Dec 24, 2002 | 12:28 AM
adam c's Avatar
Cheap Bastard
I do have big hands
Turblown
Vendor Classifieds
Oct 17, 2020 03:25 PM
msilvia
164
Mar 8, 2020 08:00 PM
binz
Oct 2, 2015 03:52 PM
Snook
23
Sep 30, 2015 11:36 AM
