relocating charcoal canister
Old Dec 21, 2002 | 07:16 PM
82transam's Avatar
Never Follow
About a week ago I took out the sub zero start tank on my car. Now that I have that space open I'm thinking it would be cool to move the charcoal canister from the strut tower over to where the sub zero tank was. Can I just put it there? Or does it have to be where it is for a reason? TIA
Old Dec 21, 2002 | 07:22 PM
85RX7GS's Avatar
In general, the charcoal canister can be put just about anywhere. It's part of the emissions equipment, so just chuck it somewhere...
Old Dec 21, 2002 | 07:28 PM
82transam's Avatar
Never Follow
I would if I could, stupid NJ....
Old Dec 21, 2002 | 07:48 PM
inittab's Avatar
I read your email
Sure, re-locate it. It's used to reduce the fuel vapor emissions. Just don't remove it otherwise you'll be gaging on the stench of fuel.
Upload some pics if you do it.
Old Dec 21, 2002 | 08:18 PM
82transam's Avatar
Never Follow
Hmmm, maybe I'll be able to do it tomorrow, I'll be sure to upload pics if I do.
Old Dec 21, 2002 | 08:35 PM
Sterling's Avatar
Nikki-Modder Rex-Rodder
Mine is up underneath by my fuel pump!
Old Dec 22, 2002 | 12:35 AM
JIMMY54's Avatar
GSL-SE PRO
Yeah I put mine where the cold start assist used to be.
20 minute job at the most.
clears alot of room!
Old Dec 22, 2002 | 11:23 AM
Rx7carl's Avatar
Airflow is my life
You just disconnected the line at the back?
Old Dec 22, 2002 | 02:09 PM
82transam's Avatar
Never Follow
Well, this morning I took the mounting bracket off and moved it to where the tank was, it looks really good, but the holes don't line up, the spacing between the holes on the charcoal canister bracket is much smaller. I mounted it with one bolt to see if I liked it, and then put it back just to be safe. Jimmy: What did you do? make your own bracket or drill a new hole in the firewall? I'm kind of hesitant to do that because there is a lot of stuff back there I'd rather not drill through. also, what did you do about the lines? Trim them? modify the hard line?
Old Dec 26, 2002 | 01:36 PM
82transam's Avatar
Never Follow
shameless bump
Old Dec 26, 2002 | 02:10 PM
JIMMY54's Avatar
GSL-SE PRO
I just used holes that were already there. The lines were not trimmed.
Old Dec 26, 2002 | 08:36 PM
82transam's Avatar
Never Follow
How did you use the existing holes? they don't line up, unless i'm missing something.
Old Dec 26, 2002 | 10:00 PM
stinkfist's Avatar
Learn to swim.
You could just drill another hole in the bracket to line up with the existing holes.
Or you could do what I have done with every 1st gen I have owned (4), Chunk it in the woods next to the air pump.
The only time I smelled inside the car was when my Holley was leaking.
Mike
Check out my post count! This post is evil....EVIL, I say! Muh ha ha ha ha !
Old Dec 26, 2002 | 10:26 PM
82transam's Avatar
Never Follow
Won't work, the holes on the firewall are farther apart than the bracket's total size, so I guess I'll have to custom make a bracket of some kind. If i didn't live in NJ I would throw it out, but emmissions are a concern.
Old Dec 27, 2002 | 09:59 AM
SoRRoW's Avatar
MY NEW NAME IS ROTARY 7S
I relocated mine straight to the garbage can,
Old Dec 27, 2002 | 01:02 PM
JIMMY54's Avatar
GSL-SE PRO
I did it a while back so i don't exactly remeber if I used just one hole or two. But i Do know that i removed the cold start bottle and the cruise control crap which may have lead to more holes to use. But even one hole would be enough to hold it up, doesn't weigh that much.
Old Dec 27, 2002 | 03:21 PM
Rx7carl's Avatar
Airflow is my life
Best place for it!
Old Dec 28, 2002 | 12:10 AM
82transam's Avatar
Never Follow
agreed, but seeing as i live in NJ and can't put it there I'll have to settle for putting it on the firewall, it looks good there.
Turblown
Vendor Classifieds
Oct 17, 2020 03:25 PM
RuffRx7
Oct 1, 2015 03:08 AM
choddaboy
Sep 26, 2015 06:35 PM
