Tranny problem.
Old Dec 21, 2002 | 03:55 PM
lerch32's Avatar
Tranny problem.
I had, what I thought was a bad pilot bearing. You know you get the humming when in neutral with the clutch out. So I pulled the tranny out, and did the 5th gear syncro, and installed ACT clutch with a new pilot bearing. Now sound even worse. I am thinking the input shaft bearing is going. Anyone else have this problem, and if so what was it, and how did you fix it. Thanks guys.
Old Dec 21, 2002 | 08:56 PM
lerch32's Avatar
Old Dec 22, 2002 | 10:15 AM
lerch32's Avatar
anyone
Old Dec 22, 2002 | 10:22 AM
duboisr's Avatar
PULL the trans apart and check all bearings, it could be the rollers between the input shaft and the mainshaft ..you can know for sure .
Jetlag
Sep 29, 2015 06:52 AM
