what do u think of the t04e with hks racing waste gate
Old Dec 20, 2002 | 11:45 AM
rbrtech's Avatar
i found one realy cheap but i need the manifold is it worth the time?
Old Dec 20, 2002 | 12:17 PM
Kurgan's Avatar
Gaijin Racing
what are the specs on the t04e?
Old Dec 20, 2002 | 12:25 PM
great street turbo, couple guys i knew has that turbo and putting close to 400rwhp. the hks t04e spec is
COMPRESSOR:
-Wheel- 57 Trim - 56.3 Inducer / 75.0 Major
-Housing- 100 Inlet / 60 Outlet - 0.60 A/R
TURBINE:
-Wheel- 62 Trim - 74.1 Major / 58.1 Exducer
-Housing- T04 inlet / Insert type outlet - 0.70 A/R
Old Dec 20, 2002 | 12:28 PM
rbrtech's Avatar
do u know where i might be able to pick up a moanifold and what other mods will i need
Old Dec 20, 2002 | 12:37 PM
hks sell them and xs engineering have them as well. you need a downpipe, wastegate, oil feed line, inlet filter that's about it.
Old Dec 20, 2002 | 12:40 PM
midnight's Avatar
this turbo wont need a street port correct
Old Dec 20, 2002 | 12:42 PM
midnight's Avatar
i paid 500 for the lines turbo and wastegate. what do the manifold and filter usaly run
Old Dec 20, 2002 | 12:44 PM
find a used one for about 300 bucks? new they are about 700.
Old Dec 20, 2002 | 12:55 PM
mjw's Avatar
mjw
COMPRESSOR:
TURBINE:
Are you sure that is correct on the exhaust A/R? My documents I got with the kit list it as .84 A/R, it is also stamped .84 on the housing.. .70 seems real small to me.
*edit*
Those specs are just copied from the HKS website right? If so that is just their general application TO4E you can buy separately, the one in the FD3S kit comes with a .84A/R exhaust. 400RWHP just wouldn't be possible on a .70A/R
Old Dec 20, 2002 | 12:57 PM
mjw's Avatar
mjw
That is a score if you got it for that much, the manifold is about $600-700 new like listed above. I am just using a K&N filter for my kit (HKS foam sucks), the filter cost me $35 from Martelbros.com. You would also need to get a downpipe made and then you are almost there, just bolt it all together.
Matt
Old Dec 20, 2002 | 01:01 PM
rbrtech's Avatar
thank you for the help
Old Dec 20, 2002 | 07:24 PM
Originally posted by rbrtech
edit*
sure it's possible. carcarzy made 400rwrhp with the same exacty turbo. try to look him up. he is a user on this forum.
Old Dec 23, 2002 | 03:17 PM
Kurgan's Avatar
Gaijin Racing
Um, he didn't say it was a HKS t04e. T04e come in all different configurations... still need to know what THAT turbos specs are...
Old Dec 23, 2002 | 03:43 PM
mjw's Avatar
mjw
Good point, we all got sent off on a tangent.
Old Dec 23, 2002 | 06:50 PM
rbrtech's Avatar
i have not recieved the turbo yet to know the make so i will let you know but i went ahead with the purchase
High_Carb_Diet
Power FC Forum
Sep 5, 2015 09:07 AM
