Apexi RX6
Old Aug 7, 2001 | 09:15 PM
JBC's Avatar
JBC
Apexi RX6
To the guys with Apexi RX6 turbos what type of intercoolers are ya'll using? Are there fitment issues with any specific intercoolers M2, PFS, CWC etc....?
Old Aug 7, 2001 | 09:39 PM
94touring's Avatar
I use the apexi fmic. We had to move the radiator and the ac condenser, not to mention get a smaller battery.
Old Aug 7, 2001 | 09:49 PM
Poweraxel's Avatar
Re: Apexi RX6
The apexi turbo kit comes with piping that is for the APEXi FMIC only..if you have a different IC you just need to cut and fab a pipe to lead to your IC..not really a big deal
Old Aug 9, 2001 | 02:02 PM
ApexRX7's Avatar
I have the APex FMIC from RX7 Fashion and didn't have to relocate the radiator, the battery or anything. AND the best part is the i/c fills up the mouth on my bumper perfectly! Oh yeah, it's huge, too...
Old Aug 9, 2001 | 05:55 PM
MeLoco's Avatar
It works fine with M2 race also less pressure drop,spinner aint working so hard. Relocated battery means better balance and alot easier than pulling of the nose.I have a twelve inch fan on my intercooler works absolutely fantastic for heat soak and keeping my under hood temps cool it doesn't even feel warm under there when a go for the latch.
Old Aug 9, 2001 | 07:00 PM
Cheuk in Seoul's Avatar
I use a CWR intercooler... still without a duct.
But the piping issue was relatively simple. I cut the intercooler intake pipe and it fit perfectly.
Old Aug 10, 2001 | 09:40 PM
RX-7 Pilot's Avatar
I run a custom SMIC & relocated the battery to the trunk. Helps keep that stealthy appearance but with a bite! No problems with heat soak.
Old Aug 12, 2001 | 09:43 PM
Under PSI's Avatar
I too use the CWC IC (NO DUCT!) and it was only one cut I had to make to make it fit.
-Matt
ls1swap
Jun 3, 2024 03:25 PM
