help!! it wont go into REVERSE...
Old Dec 18, 2002 | 08:34 PM
corkbone's Avatar
I tried and tried, I put it into other gears, checked the gear oil, and i cant figure it out. It wont go into reverse. Anyone have this problem. It was fine when I took it out of my old car.
Old Dec 18, 2002 | 08:59 PM
Manntis's Avatar
add to cart
Are you having any trouble with 4th gear at all?
Old Dec 18, 2002 | 09:02 PM
85RX7GS's Avatar
Do you have a new clutch installed? If you do, I think I know what's going on.
Old Dec 18, 2002 | 09:08 PM
Try putting the driveline in ... is it grinding at all? whats it doing... you try dbl clutching to get it into gear???
Old Dec 18, 2002 | 09:11 PM
corkbone's Avatar
Yes I just put in a clutch from racing beat.
What do u think it is?
Old Dec 18, 2002 | 09:19 PM
85RX7GS's Avatar
Will the car go into any gear?
Old Dec 18, 2002 | 09:21 PM
85RX7GS's Avatar
When I put my new clutch kit in, I put the car in gear and jacked the rear end up in the air. Then I started the car, in 1st gear, and let it run for a bit and then hit the brakes. If you push the clutch in, you should be able to shift into any gear. Try it out in reverse.
Old Dec 18, 2002 | 09:55 PM
corkbone's Avatar
okay
ill give it a shot. thanks, hope it works
Old Dec 18, 2002 | 11:55 PM
82transam's Avatar
Never Follow
I'm confused, your saying that pushing in the clutch will enable you to shift into any gear, umm... thats what normally happens. Why would the rear have to be jacked up for any of this? I must be missing something.
Old Dec 19, 2002 | 01:56 AM
REVHED's Avatar
Hunting Skylines
You might have to adjust the clutch pedal if you just put a new one in.
Old Dec 19, 2002 | 02:18 AM
xlversatilelx's Avatar
hmmm i had the same problem, sometimes it wont go into any gear, any help, someone told meeh it could be the gear oil, does any one where it is located and hwo i can change it thanks
Old Dec 19, 2002 | 02:53 AM
Hyper4mance2k's Avatar
The Shadetree Project
allways park on a hill
Old Dec 19, 2002 | 03:59 AM
Rotor13B's Avatar
Wassup!!
I had this problem once, ended up being a penny stuck under the shift boot causing it to not go in reverse. Found out at the most inopertune time too, I was out fooling around with some friends drag racing out in the country and lo and behold, here comes the sheriff out of know were!!!. Me and this guy were already going at it when he turns his lights on, and I was like ****!! slammed on the brakes, went to turn around, ****!!! NO REVERSE!! I got real lucky on that one, he let us off with a warning because he says technically i'm not in my jurisdiction. He said he had been watching us there for a few weekends now just sitting near a electrical substation with night vision goggles. That was the last time I ever street raced again. this was 3-4 yrs ago. lol
Old Dec 19, 2002 | 08:01 AM
85RX7GS's Avatar
You are missing something
After I installed the clutch kit, I couldn't get the clutch to disengage when pressing the pedal. So I jacked the rear end up and started the car in 1st gear. Then I pushed in the clutch (this didn't stop the wheels from turning, as it normally does) and lightly applied the brakes. Snap! The clutch disengaged and I could now shift into any gear using the clutch. The reason why it was sticking was that the pilot bearing that I used had a really tight fit. Anyway, no harm done and it works like a charm.
Old Dec 19, 2002 | 01:19 PM
82transam's Avatar
Never Follow
Ah, I got it.
Old Dec 19, 2002 | 02:21 PM
85RX7GS's Avatar
That shouldn't have to be done, but it worked.
Old Dec 19, 2002 | 08:11 PM
Sterling's Avatar
Nikki-Modder Rex-Rodder
-Sounds like that would pretty much kill that tiny bearing, no?
Old Dec 19, 2002 | 09:02 PM
85RX7GS's Avatar
No not really. I didn't slam the brakes to the floor. I tapped them and that's all it took. The bearing works great. Ask me how I know
Old Dec 20, 2002 | 12:34 PM
specRX7_22's Avatar
usually if its just hard to get into gear but will go eventually just double clutching will do the trick but i dont know about not going in at all.
--eric
Old Dec 22, 2002 | 09:57 PM
corkbone's Avatar
havent figured it out
Ill just drive it and hope it will start working..
SleeperRX7
Sep 17, 2010 04:09 PM
alexjaii
Jul 4, 2009 09:23 PM
kekoa
Oct 23, 2007 04:07 AM
