stripped exhause stud or bolt!!! HELPME!!!
Old Dec 18, 2002 | 06:44 PM
Hyper4mance2k's Avatar
The Shadetree Project
Angry stripped exhause stud or nut! HELPME!!!
help me quickly i don't know what to do and this piece of **** is my daily driver!!!
i was taking off my exhaust manifold to put my header on and the last nut i try to get off just stops comming at the verry end of the threds so it just spins there now is the nut or stud stripped and now i cant get it off or back on so i can't drive the car at all some one help me please!!!!
Old Dec 18, 2002 | 07:21 PM
Rotor13B's Avatar
Wassup!!
Best I can tell you is to put some vice grips on the nut and pull and turn at the same time. I have used this method before to take off stripped nuts off of threads. You will probably have to buy a new stud, Ace hardware is where i get my studs and bolts from.
Old Dec 18, 2002 | 07:38 PM
MIKE-P-28's Avatar
Driven a turbo FB lately?
Re: stripped exhause stud or nut! HELPME!!!
Anytime you mess with exhausts always inticipate stud or bolt problems, its usually a given... Try the pliers or visegrip approach if that dont work, screw the nut back in and buy a tap tahts appropriate for the stud and tap the threads back to where they need to be, then remove the nut...
Old Dec 18, 2002 | 07:44 PM
Project84's Avatar
Open up! Search Warrant!
torch. Heat it up and take it off while its hot. Don't burn your self.
Or try The gator grip. I don't know how they work on rusted bolts. Here is a link to their site though. If you use it, tell us how it works out.
toplessFC3Sman
Mar 20, 2018 01:54 PM
invinciblejets
Sep 13, 2015 08:22 AM
