shift knob rotation
Old Dec 18, 2002 | 05:19 PM
hornbm's Avatar
FD > FB > FC
shift **** rotation
got my transmission yesterday, but the shifter **** is turned 90 degreed to the right.
I tried to straighted out but there doesnt seem to be any way to do it!
Old Dec 18, 2002 | 05:28 PM
Keaponlaffen's Avatar
turn it It'll turn, but make sure you check it for set screws, etc that might be holding it on...
Jeff
hornbm's Avatar
FD > FB > FC
woops forgot my question, how the hell do I rotate it?
Old Dec 18, 2002 | 05:30 PM
just grab it with your hands and crank on it, and if that doesn't work, try everything in the house that you think might help. I used one of those rubber-band looking things from Sears to fix mine, 'cause it was cranked on like mad. Remember though, Right Tight, Left Loose
Jeff
MIKE-P-28's Avatar
Driven a turbo FB lately?
see the big locking nut under the ****, loosen the nut, rotate the **** just a little before its straight hold the **** and tighten the nut
Old Dec 18, 2002 | 05:32 PM
hornbm's Avatar
FD > FB > FC
I didnt see any set screws on there....
There's a metal part right below the **** that has a set of parell sides... If I remember this allowed me to get my automatic shifter off.
I tried turning it and it felt like It would break I'f I turned it anymore.
Old Dec 18, 2002 | 05:33 PM
hornbm's Avatar
FD > FB > FC
is there somthing backwards here??? which direction should I turn it??
oh, you gotta turn the bottom lock nut to the right, in effect tightening it, to loosen it off the bottom of the ****... then unscrew the ****. I forgot about the locking nut, as I have a '79 without one.
Jeff
Old Dec 18, 2002 | 05:38 PM
hornbm's Avatar
FD > FB > FC
ok now when I tried turning it today... it seemed to have a middle area of free play... before turning it in either direction
I tried turning it to the right, and it felt like the hole stick was going to tear out of the car....
Also I'm not sure the transmission is from an 85, it could be any year that has a 5 speed.
All the people knew at pineapple is that it was a 12a, but had no idea what year it came out of.
Old Dec 18, 2002 | 05:42 PM
Mr. ImportGuy's Avatar
Looking for Another RX7
Well be careful with tools lol, I used robo grips and twisted the whole shifter and broke the **** lol....
Old Dec 18, 2002 | 05:44 PM
hornbm's Avatar
FD > FB > FC
thats what I'm trying to avoid..... if I twisted it any farther I'm sure that would have happened.
Old Dec 18, 2002 | 11:02 PM
riffraff's Avatar
smog nazi destroyer
same way you rotate a screwdriver. you grab ahold and turn (and i donot mean turn yourself like you would when spining with your head pressed against something stationary when you are drunk)
Old Dec 19, 2002 | 07:55 AM
jeremy's Avatar
male stripper
i didn't realize fb's had locknuts on the shifter *****.
Old Dec 19, 2002 | 09:49 AM
inittab's Avatar
I read your email
lefty loosy
righty tighty
Old Dec 19, 2002 | 05:21 PM
hornbm's Avatar
FD > FB > FC
except... since the nut is screwing INTO the ****.. it would be backwards............ its like looking at a bolt from the other side.
Old Dec 19, 2002 | 05:24 PM
Ok, did you figure it out? If not, here's what you have to do...
Turn the lock nut clockwise until it's down and outta the way
Then turn the shift **** itself counter-clockwise until it's off.
Sit back, have a beer, and ask yourself why it took almost 2 days to figure out how to get a stupid shifter **** off of it's shaft....
Jeff
Old Dec 19, 2002 | 05:29 PM
hornbm's Avatar
FD > FB > FC
Sorry, I was going to make a new thread but then changed my mind...LOL
I did get the **** off... only after putting the **** in a vice, and then getting a crecent wrench to turn the nut.
After I got it off, I discovered that the threads in both of them were rusted.. and the ones in the ****, were cracked, twisted and destroyed.
I guess that would explain why it was so hard to remove the damn thing.
Looks like I'll need a new **** now!
Old Dec 19, 2002 | 05:33 PM
Good time to get a nice, shiny, polished aluminum one, or perhaps a carbon fibre one.... update the look of your interior
Old Dec 19, 2002 | 07:03 PM
jeremy's Avatar
male stripper
and drink that beer, while listening to rob zombie/white zombie.
Old Dec 19, 2002 | 09:26 PM
Yeah, add that beer to the last order.... it'll make the shift **** much easier to install
Jeff
Old Dec 19, 2002 | 10:42 PM
hornbm's Avatar
FD > FB > FC
I love beer, and I love listening to rob zombie... sounds like a good combo!
distr0
Canadian Forum
Oct 7, 2015 08:17 AM
