Aftermarket Radiator?
Old Dec 15, 2002 | 08:08 PM
Mr. ImportGuy's Avatar
Looking for Another RX7
Does anyone make a aftermarket radiator for fb's? I'm building a SCCA IT car and my radiator is pretty beat up. Should I just get another stock one or is there a better option out there?
Old Dec 15, 2002 | 08:31 PM
inittab's Avatar
I read your email
I bought a nice one from radiators.com and I'm very pleased with it. It cost something like 120 bucks.
Old Dec 15, 2002 | 08:34 PM
radiators.com who would have guessed lol! Any other options out there? Like somthing that is suposed to cool better than the oem one?
Old Dec 15, 2002 | 09:20 PM
riffraff's Avatar
smog nazi destroyer
i think mazdacomp sells them. .not sure what the specs are though.
Old Dec 15, 2002 | 09:23 PM
mazdacomp as in sells only to racers mazdacomp? If so I have no race results to join...
Old Dec 15, 2002 | 09:24 PM
Project84's Avatar
Open up! Search Warrant!
I got one from radiators.com before. The one in my wifes 96 ford escort had started leaking. Price was very competative. I think I only found one other place who had one for cheaper, and that was after I already made my order. Just a note: After market radiators are made for use in cars with auto or manual trannys. If you have a manual, there will be a plug that you will need to install in the port where the lines from a auto tranny would hook up. The port fitting is brass seated in plastic. If you tighten up the plug too tight, you will unseat the fitting and it will leak. Ask me how I know? If this happens, you can RTV over the whole fitting to stop the leak.
Old Dec 15, 2002 | 09:26 PM
RotorMotorDriver's Avatar
Seven Is Coming
Thats where I got mine. Its really nice looking . Good customer service too . I had originally ordered the wrong one by accident, and they sent me the right one completly on the honor system that I would return the other one .
~T.J.
Old Dec 15, 2002 | 09:37 PM
S2-13BT's Avatar
An Australian company - www.pwr.com.au - make high performance aluminium radiators.
They'll cool better than an OEM replacement and look much better. The only drawback would be the cost. You can get a matching oil cooler and intercooler as well if you want.
Old Dec 15, 2002 | 09:46 PM
Well I expect to pay more for an aftermarket radiator. Which is fine because I want the best cooling as this is a racecar and I will be running the **** out of the motor. Thanks for the info. Oh and I didnt see a listing for our cars on the PWR site. Unless I missed it.
Old Dec 15, 2002 | 11:36 PM
riffraff's Avatar
smog nazi destroyer
but if you tell them that you are building a car for race purposes, then they will let you join for a certain amount of time.. and then when you get time slips, just send them that and they will continue your membership.
Old Dec 15, 2002 | 11:43 PM
BadAssRX-7's Avatar
The AUTO DOCTOR
i took a *** raping on my 1" core alm. rad for my 83 l.e. its a short rad with the oil cooler under it... looks good cools good but DAM my *** hurts..... srx7.com
Old Dec 16, 2002 | 12:23 AM
851stgen12a's Avatar
Off riding sportbikes!
http://www.indigospeed.com/indigoSCradiators.htmlthis looks like a very nice radiator... does anyone have any info??
Old Dec 16, 2002 | 12:27 AM
spoolin's Avatar
www.radiatorbarn.com i bought mine last week. 3-row with free shipping and a t-shirt for $121.xx
only compalint was that there were no nuts on the back of where the shroud mounts. other than that, great piece got it in two days....and did i say a free t-shirt
Old Dec 16, 2002 | 12:33 AM
spoolin looks like a good deal. They don't list a radiator for a 83' RX7. But they have them for 85's with 1.3L (aka 13b). Would this work on my 83' 12a?
Also spoolin where did you find the 3 row radiator. They list only the 1 row for the first gen. If you could tell me which radiator you got it would be great!
Old Dec 16, 2002 | 06:41 PM
I'm retarted I completly forgot about mazdatrix!! They have what I'm looking for thanks though.
Old Dec 16, 2002 | 08:08 PM
CrazyJoe12a's Avatar
I have a 3 core from MazdaTrix in my 82. It's used primarily for AutoXing and I havent had any problems so far.
Old Dec 16, 2002 | 09:50 PM
Pele's Avatar
Right near Malloy
Okay, someone with more money than me, try my idea... Well, it's not my idea, but the same request was made of me. (Orignial conciever didn't have the funds and neither do I... I think it was someone on the www.MazSpeed.com forum.)
Anyhow.. You need two radiators from different year RX-7's...
One short thick kind from a 1979-1982, and one tall thin kinda from a 1983-1985...
The early one is thick enough that a 3 row core can be fit into, the Later one has larger surface area, but is too thin and can only fit the standard 2 row core in it's end tanks.
Goto a radaitor shop and tell them to keep the end tanks off the early radiator, and the mounting brackets off the later radiator. Throw everything else out. Tell them to recore the radiator so it's the same height as the later radiator, but use a 3 row core, aluminium if possible...
See how that works. Might require an electric fan, but I doubt it. In theory, you have a tall style three row radiator.
Old Dec 16, 2002 | 10:43 PM
diabolical1's Avatar
another idea to throw out there ... maybe try one of the aluminum upgrades for the Gen II cars ...
Old Dec 16, 2002 | 10:56 PM
rogan's Avatar
throwing this out there for the hell of it, do not stone me..... I once upon a time several years back put a radiator in a '79 rx-7 from autozone........
Old Dec 16, 2002 | 11:19 PM
Yea the point is im looking for a higher performance race application radiator. I could find a OEM replacement easily. If that was what I was looking for.
Old Dec 17, 2002 | 01:04 AM
check out ebay, i was lookin around on there earlyer and saw a company selling aftermarket ones for 1st gens
Old Dec 17, 2002 | 10:16 AM
buttlips's Avatar
I believe that SDJ Motorsports www.sdjmotorsports.com sells an aluminum racing radiator that has the same external demensions as a stock 1st gen radiator, so it bolts in without the need of fabrication.
JoesFC
Oct 5, 2015 08:10 AM
