suspension swap...
Old Dec 13, 2002 | 10:35 PM
onepointone's Avatar
i say what i want
suspension swap...
can someone help me out...
i need to know EVERYTHING i need to get my 1985 gs coverted to gsl-se suspension... im not getting the struts, shocks, and springs because they will be replaced with eibachs and tokico illuminas. can i use my stock sway bar? i heard somewhere that i need the master cylinder.. ect.. theres a guy with a gslse parts car and im trying to get the suspension off, he just needs to know waht i need
Old Dec 13, 2002 | 11:46 PM
gen1mike's Avatar
you need the master cylinder and ebrake cord i think.
Old Dec 14, 2002 | 04:41 AM
RacerX7fb's Avatar
paradox
You can use the stock sway bars. Take the power booster as well as the master cylinder if it's different
Old Dec 14, 2002 | 11:31 AM
i say what i want
power booster?
Old Dec 14, 2002 | 11:35 AM
RotorMotorDriver's Avatar
Seven Is Coming
Rear axle (disc to disc) . Front hubs and/or spindle thingies (whatever theyre called), discs, calipers, and that it I think. You might need the brake lines, but I think since you have a GSL rear end (you do dont you?) you may not need it. Also, the proportioning valve Ive heard is a possibility too. Im gonna look for that site i was reading on the other day. Ill post when I find it.
~T.J.
Old Dec 14, 2002 | 11:42 AM
MIKE-P-28's Avatar
Driven a turbo FB lately?
Direct bolt in man, just get the e brake cords fromt he axle to the body they are different everything esle is a piece of cake...
Old Dec 14, 2002 | 11:47 AM
Seven Is Coming
Here ya go:
http://www.mazspeed.com/axel.htm
~T.J.
Old Dec 14, 2002 | 12:43 PM
i say what i want
yea, i have the gsl rear end, im not EXACTLY sure what year though, i think i can go under my car and get somethign to find the year, but the owner before me did it.
do i really need the master cylinder and p.valve? if not i dont want to pay the extra money for it.
Old Dec 14, 2002 | 03:33 PM
rotor vs. piston's Avatar
Function > Form
If you don't know what year your rear end is, you want to get the drive shaft of the GSL-SE just in case the rear end you have has the smaller flange.
Postman09
Sep 29, 2015 11:23 AM
