I have an annoying odd whining noise?!?...
Old Dec 12, 2002 | 06:01 PM
...But then my girlfriend goes home....
Na, but really, I have a '79 12a bridgeport with a 5spd manual and it also makes a whining noise. Its in first and second mainly, and in the higher revs, it sounds like its in the front of the gearbox/clutch/flywheel area. Its a very metallic sound almost like thin metal rubbing very lighty on the flywheel as it spins. Also, the other day i discovered there were no bolts in my rear gearbox mount, the mount was there but not bolted to the box. so i bolted it up, BUT, I had to redrill holes in the bracket, cos they wouldn't line up. Is there ment to be a mount or spacer that goes between the g/box and the rear bracket going across the tunnel? cos i dont have one, maybe my trans is sitting low causing odd noises?? thats what I'd thought of so far anyway.....
anyone have any idea's maybe?
Old Dec 12, 2002 | 06:14 PM
Project84's Avatar
Open up! Search Warrant!
Sounds like it could be bearing noise. Got pics of the bracket and how you got it attached to the tranny? There should be a bracket held to the tranny with 2 bolts. From that bracket, there are 2 studs that go into the crossmember, and 2 nuts on the studs. Then the crossmember is held to the car with 2 bolts.
Old Dec 12, 2002 | 06:30 PM
ah huh, I have the crossmember bolted DIRECTLY to the transmission casing. 2 bolts, through crossmember from underneath into bolt holes in g/box.
___]__
...........\____ <----Gearbox sitting ON crossmember
___________\
`````{][} <-- crosmember
``Bolt through here
<---- front of car
srry I cant get a pic right nw cos im at wrk. But if that makes any sense??!
Old Dec 12, 2002 | 08:06 PM
Project84's Avatar
Makes purfect sense. You need the spacer bracket thingy. Time to hit the J-yard. Good luck, and hope that fixes the noise. If not, inspect the clutch, throw out bearing, and pilot bearing for damage from the transmission not being aligned properly. If that doesn't fix it, go back to the scrap yard, find the car you robbed the spacer bracket from, and grap the whole tranny. I doubt there is enough stress on the tranny input shaft to damage the internal bearings, but it is possible.
Old Dec 12, 2002 | 08:52 PM
Cheers man,
My theory was right.
Keaponlaffen's Avatar
My tranny did the whining noise in all gears except 4th, so I figured it was time to replace... put a new (used) one in from the junker's, and it solved my problems!
Jeff
Old Dec 12, 2002 | 10:42 PM
RotorMotorDriver's Avatar
Seven Is Coming
You can get that rubber "spacer" piece prom Schucks new for $30. Ask me how I know . I had to replace one that was actually in about 6 pieces when it came outta the car. It was a wonder it was still in there to begin with. After I did my engine swap and went to put the tranny crossmember in so I could take it off the jack, I noticed this thing missing so I just set the tranny on a small block of wood in there to make up the lack of size difference until I could get to the store to get a new one.
~T.J.
jim_chung
1st Gen General Discussion
Oct 4, 2015 09:09 AM
nycgps
30
Sep 29, 2015 12:02 AM
BLK 93
11
Sep 9, 2015 10:56 AM
