How to make a Turbo-2 produce 350hp?
Old Aug 6, 2001 | 06:30 PM
smith88's Avatar
You might look into these:
Magnecor 10mm wires with NGK plugs.
Walboro fuel pump.
Bigger Aluminum Radiator.
Not sure about any of the other stuff, but it looks like your list is going along nicely with Apexi.
Good luck and keep us posted on all the mods.
Old Aug 6, 2001 | 06:33 PM
Well, your list sounds great...I'm not a turbo guy personally, but have delt w/ them(and helped replace the motor in one). The biggest bang will come from your upgraded turbo, but you can't get crazy w/ a nice turbo unless you have the fuel to support it. Upgrading your injectors to like 550 or 720cc should be good. Get a fuel pump from Rx7.com thats like $270 and will support up to 500HP. Also, exhaust will help. Racing Beats exhuast claims a 60HP gain. So right there w/ turbo, fuel, and exhaust...your looking at OVER 300HP. Get a boost controller and engine management system to limit it all and you can easily get that 300HP you want. Also, if your rebuilding your engine..a street port will gain another easy 35HP or so on a 4port T2 motor...TURBOII guys..help this guy out! I'm sure there is stuff I didn't really go over, I'll wait to see what the T2 guys have to say!
Old Aug 6, 2001 | 07:09 PM
Bean's Avatar
just 350? is that rwhp or bhp?
as far as a turbo goes; if you want to save a little money get your stock turbo converted to a hybrid... make sure you get the wastegate ported like f-in crazy
get 720 secondaries...
as far as fuel control goes a Super-AFC can control the injectors... or if you have a 89-91 car and a 89-91 motor you can get an upgraded ECU...
as far as injectors go; don't waste yout time with Greddy; get some good new RCs
the Apexi GT spec is not really needed; but still cool...
the N1 downpipe is pretty much a waste; it doesn't flow any better than any of the others...
are you planning on getting a test pipe?
the Greddy FMIC is pretty good; i'd go with that or a custom one...
I'd get the engine ported too
you'll prolly be making more than 350hp with that setup running 15psi...
should be good for mid 12s at least with a good launch
but please don't forget the suspension mods and everything just get some good shocks and springs; and make sure all the rest of the suspension is working in tip top shape... (ie. a lot of T2s break their Diff mounts like mine has)... the ball joints may need replacing...
I'd get a TurboXS type-h racing or normal Type-H blow-off valve... it sounds WAY better than an Apexi' imo...
There's a guy in town with a XS on his MR2 turbo and its BADASS... you can hear him from very far away... and it sounds gooood
Old Aug 6, 2001 | 07:32 PM
Also, pick up the new SUPERSTREET issue...the september issue is all about turbos and mainly turbo controllers, etc...they dyno several top brands...its a good issue for turbo lovers..
Old Aug 6, 2001 | 07:36 PM
Dyre's Avatar
Your Opinion is Wrong
Heres my list for you, this is the way to do it right-
*Mild/Medium Street port (Racing Beat is Great, so is Atkins Rotary and many more)
*Haltech ECU (VERY IMPORTANT)
*Custom TO4 Turbo (w/ Crispeed Manifold- should be cheaper and more powerful than the HK$ and GReddy kits)
*Custom FMIC and Piping- Theres lots of great cores out there that cost alot less than the ~$1200 GReddy and HK$ want for thiers- Local muffler shop should be able to bend up the pipes super easy for you
*Upgraded fuel pump (i think the popular walbro 255 will work for you)
*720cc/min primaries ~1200cc/min primaries (probably way overkill here 4x 720 should accually be fine)
*Any of the popular BOVs will work since you wont be running a ton of boost
*FULL RACING BEAT TII EXHUAST! Screw that 'tuner' ****. Its not worth the price. For the price of a GReddy or Apexi CAT-BACK you can get the FULL 3" RB exhuast with a SS pre silencer and SS muflers.
*Maybe need a custom DP to go with the crispeed manifold and turbo
*Build your own intake from a universal K&N filter for $40
*Stock Wires and Plugs are fine. Use only NGK plugs- Using 9's all the way around will give you a little better highway performance
*Stock Ignitors are fine, you may want to add a CDI ignition box
*Remove all the emmisions crap- wont need it with the Haltech anyways
*Gauges man! Gauges! EGT/Boost/Water Temp/Fuel Pressure/Oil Pressure/Oil Temp! The first two are manditory, the rest are good
*You'll need to do some work on the suspension as some stuff will be worn out
*Roll Cage?
*clutch/flywheel? ACT makes great clutches
If you run 10psi you can probably put down 300rwhp with this setup- it might even make that HP with less boost. And if you find it too slow you can turn up the boost and re-tune it if nessicary.
Old Aug 6, 2001 | 09:01 PM
RETed's Avatar
That's a LOT of money being thrown into a car that's (relatively) not that fast...
Why you doing this???
-Ted
Old Aug 6, 2001 | 09:12 PM
TurboMike's Avatar
Because maybe he wants to drive an RX-7 Turbo rather than a V8 weilding domestic.
Old Aug 6, 2001 | 09:17 PM
PaulC's Avatar
Three spinning triangles
From: Been all around this world and still call Texas home (Ft Worth)
I agree with Ted drop some cash into it to make it quick and dress it up tastfully and make a nice cruiser out of it. Thats what my NA is gonna become.
Old Aug 7, 2001 | 08:27 PM
Bean's Avatar
to the guy above who said that the RB 3" is the best...
doyou know what a Apexi' GT is?
two is not neccesarily better than one
and if i remember right; a pipe that gets bigger as it goes to the back is a lot better than a straight same size pipe...
a good bit more mid range...
plus a GT-spec looks a lot better than a bland RB 3"
Old Aug 7, 2001 | 09:40 PM
RXTASY1's Avatar
What the hell are you talking about Ted?
With those mods, he would be well in to the 11's!
I guess he could go out and buy a C5 for $45k that would put him in the mid 12's! Now that's a lot of money!
I don't know what "relatively" fast means to you, but any car that runs in the 11's or 12's is just plain fast.
There are a few mods that were mentioned, he could do away with and still have a freakin fast car.
Old Aug 7, 2001 | 09:41 PM
Dyre's Avatar
I think all the 'tuner' mufflers look like crap- Its just me. if you dont have a 120mm pipe, dont put a 120mm tip on the mufflers... but thats just me.
Also, im not conviced that thier progesivly larger pipes is a good thing- More pipe at the end means the exhuast could cool as it goes down the pipe, therefore the the exhuast loses energy, and slows down, creating back pressure. I always thought you wanted to keep the exhaust as hot as possiable till it exited the exhuast.
Either way, Apexi/GReddy mufflers are ugly, and definatly not my style-
Old Aug 7, 2001 | 10:21 PM
RETed's Avatar
The mods list looks like someone picked all the parts from a catalog.&nbsp TurboNate has already replied saying he gets substantial discounts with his shop connections.
Almost nobody nowadays puts together a show car from an FC3S - they are all at least FD3S's.&nbsp This is why I was questioning why anyone would do this.
There are "cheaper" ways of creating a "quick" FC, and most of those mods do NOT include most of the bolt on parts and kits available to most consumers.
For example, a bare-bones T04 is about a grand.&nbsp An HKS (collected) turbo manifold is $200.&nbsp Additional lines and piping is another $500.&nbsp This means for under $2,000, you get a turbo system capable of producing 500hp to the wheels, which can get you into the 10's!&nbsp Go with an XS Silvia IC core with their endtanks and some custom piping is going to be cheaper and a helluva lot larger (IC core) than any of the typical GReddy or HKS IC kits out there.
-Ted
Old Aug 7, 2001 | 10:27 PM
RETed's Avatar
I'm sorry, please go read upon your turbo tech before making such ignorant comments like this.&nbsp Turbo engines want the BIGGEST exhaust system you can slap onto it, PERIOD.
ALL the A'PEXi N1 systems (including the GT-Spec) were designed for STOCK TURBO AND ENGINES.&nbsp This does NOT apply to bigger turbos.&nbsp The GT-Spec N1 runs a 65mm flange at the beginning; 3" is 76mm.&nbsp It doesn't take much to see which is bigger.&nbsp BIGGER IS BETTER, in this case.
Hell, if you want pretty exhaust systems, you're in no qualified position to make recommendations on what the best performing one is.
-Ted
Old Aug 7, 2001 | 10:56 PM
TurboII RudeBoy's Avatar
Post count is over rated
ooooo RETED GAVE U A BITCH SLAP,HAHA.
Old Aug 7, 2001 | 11:52 PM
PraxRX7's Avatar
Why mod an FC...my opinion
Personally, I prefer the design, ride, and feel of an FC well over that of an FD.
I know many people who share my thoughts on this.
Besides, that is the same thing I want out of my car, 350 HP at 12-15 psi.
I love my FC Turbo II '89 and it will be very showy when I am done with it. Would be nice if I had my own shop to work in though...ah well.
Old Aug 8, 2001 | 02:32 AM
Dyre's Avatar
Bahhaha
God damn Ted- You think just like i do.
BTW, the Racing beat system is accually 3.15" or 80mm i think.
Wanna turn my car into the Bakersfield Rep for K2Rd. I want a To4.... and i just bought more block off plates from you guys. hehe
Old Aug 9, 2001 | 01:36 AM
RETed's Avatar
Originally posted by AMIR KHALED
RETardTED, This is the 2nd Gen. site, that's why he asked the question at this site not at the 3rd Gen FD site. Please don't start comparing RX-7 Generations.
I mentioned a few words on how an FD is more showy, and you got the gall to insult me?
Boy, what is this world coming to...
*SIGH*
If you wanna get techncal, this is an RX-7 SITE.&nbsp This is a 2nd gen SECTION or FORUM, not a SITE...
-Ted
Old Aug 9, 2001 | 01:49 AM
Felix Wankel's Avatar
Super Newbie
Dude, whats your deal? Ted's just trying to help.
And for the exhaust...why buy it? Build it yourself (if you don't care about loud exhaust volume).
A straight piece of 3" pipe and a couple U bends is relatively cheap. Throw a nice UltraFlo on it and you're set. Then you at least have a lot more choices for the tip design. (I still say the RB looks alot better than the Apex'i stuff)...
Old Aug 9, 2001 | 06:48 AM
RETed's Avatar
RETed slipped in a little cheap shot, about how the FC is not a fast car to begin with, he should keep his bullsh*t opinions to you and himself
Oh boy, now I'm GOING to INSIST on an apology from you for this...
I did not make a "little cheap shot"; I was pointing out a FACT.&nbsp Can you tell me how many FC's you know of that carry major media coverage?&nbsp Now how many FD's you remember...Adam Saruwatari, Ray Lochhead, Ari Yellon of RX7.COM, Fast & the Furious...&nbsp NUFF SAID.
Now, anyone that knows me personally KNOWS that I HATE FD's with a passion.&nbsp I think Mazda blew it BIG-TIME when they rushed the FD into production to beat the JZA80 Supra to the marketplace.&nbsp The FD (especially 1993's) are trouble-prone and a nightmare to up-keep.&nbsp Yes, it has more power and the fancy double-wishbone, but nothing an FC with a full suspension, big T04 turbo, and Haltech can't take of.&nbsp A typical used FD is priced around $15k - you can buy a good FC turbo for $5k.&nbsp So how much go-fast goodies you can get for $10k???&nbsp Enough to roast a stock to mildly modified FD, no problem...
I'd never own an FD even if it were given to me free.&nbsp I HATE working on those things, and nothing short of a big single turbo conversion would make it work reliably; that stock twin-turbo system is a nightmare!
Now, you question my loyalty to the FC3S?&nbsp You're dead-wrong about that.&nbsp Where's my apology!?!!?
Boy you don't you look really stupid now???
There better be a reply within the next few minutes, cause I caught you posting your last reply within the past 10 minutes!
-Ted
Old Aug 9, 2001 | 07:17 AM
RETed's Avatar
Boy, what a waste of time...
-Ted
