Waterpump Underdriven? Ted?
Old Aug 6, 2001 | 04:25 PM
Sebring7's Avatar
Would removing the air pump, and A/C belts cause the waterpump to become underdrive, thus causing the car to run hotter? Because recently I did 2 things at once, which I shouldn't have. I adjusted the TPS, and Fuel ratio...and also removed the A/C and Air Pump belts, and now the car is running warmer than usual. Also, at startup it sometimes the Add Coolant light on the idiot light comes on.
TYIA
Old Aug 6, 2001 | 05:53 PM
AE Turbo's Avatar
Speed from skill
OT - You should reduce the size of the picture in your sig.
Old Aug 6, 2001 | 05:55 PM
mazdaspeed7's Avatar
mad scientist
Actually, the belt is probably slipping. I would recommend the RB dual alternator pulley if you plan on not using an air pump.
Old Aug 6, 2001 | 06:18 PM
Sebring7's Avatar
nah :p I have a 20" monitor
Old Aug 6, 2001 | 06:20 PM
Sebring7's Avatar
Ya - I think I'll go with those some time soon.
Old Aug 6, 2001 | 07:52 PM
C. Ludwig's Avatar
www.lms-efi.com
The only way to change the drive ratio of the waterpump is to change either it's pulley or the crank pulley. So to answer your question, no you didn't alter the drive ratio. As said before, slippage is the most likely problem.
Chris
Old Aug 6, 2001 | 08:57 PM
RETed's Avatar
Like they all said...
Get the Racing Beat double-sheave alternator pulley and two BRAND NEW alternator/water pump belts.&nbsp This minimizes slipping of the water pump due to the deleted air pump and belt.
-Ted
Old Aug 7, 2001 | 11:27 AM
Sebring7's Avatar
thanks guys
