Efini y-pipe: Does your rub the rad filler neck?
Old Dec 8, 2002 | 03:02 AM
GoRacer's Avatar
Speed Mach Go Go Go
Just installed it and trying to slide that silicone coupler is tighter than a virgin on prom night (is there such a thing any more). Anyhow, just wondering if anyone else noticed the same thing?
Old Dec 8, 2002 | 03:41 AM
artowar2's Avatar
Absolutely no rubbing. Try a little soapy water on the coupling.
Old Dec 8, 2002 | 07:51 AM
cournal's Avatar
mine fit fine. no rubbing. still using stock intercooler.
Old Dec 8, 2002 | 07:56 AM
cournal's Avatar
let me know if you feel any more power? some boast a h/p gain. i did several other things when i installed mine. just wondering.
Old Dec 8, 2002 | 09:20 AM
jdhuegel1's Avatar
Glug Glug Glug Burp
I've heard people say there is a HP gain as well... But I too did the install at the same time as other mods...
Old Dec 8, 2002 | 10:32 AM
turbojeff's Avatar
Do it right, do it once
If your turbos have been rebuilt the compressor housings might be slightly misaligned causing the Efini y-pipe to hit the water neck. This is actally really easy to solve. Bolt the pipes up and push the crossover pipe to where you want it. It should rotate with a good push pretty easily. I just went through this.
Jeff
Old Dec 8, 2002 | 12:54 PM
adam c's Avatar
Cheap Bastard
I recently installed the efini y-pipe. Installation was easy with no problems or rubbing. I have the stock intercooler (for now). The Blitz is coming.
I did feel a HP gain, and there was a boost gain. Mazda claimed a 10 hp gain with this. I think part of the gain was due to the crossover tube being held in place. With the old crossover tube, it would flex upward under boost. So some of your boost was being wasted to expand this tube. It can't flex with the efini pipe.
Adam
Old Dec 8, 2002 | 08:03 PM
skunks's Avatar
I'm a CF and poop smith
no rubbing for me
Old Dec 8, 2002 | 08:50 PM
Quik 93 FD's Avatar
going ls
no rubbing but i bent a screwdriver tryin to get that bitch in. Fits fine now, lol
Old Dec 9, 2002 | 01:25 AM
GoRacer's Avatar
Speed Mach Go Go Go
Jeff
Thanks for the replies. I'll try the above and see if I can rotate it. There was enough clearance to slide the silicone coupler on the tube (with some sex lube "lol"). I also had to rotate the pipe to the Greddy SMIC.
Yes, I did feel a butt dyno difference. Not sure about horsepower but more responsive. I test drove it late last night and it was back up to scary fast from just plain fast.
Old Dec 18, 2002 | 12:04 AM
I wish I had my Y pipe! Still waiting for Msports to ship. Backordered.
Old Dec 18, 2002 | 06:35 AM
ttpowerd's Avatar
HARRRRRRRRR
no rubbing at all in my case.
MidnightOwl
Sep 25, 2015 10:24 PM
