What the hell do I block off?
Old Dec 7, 2002 | 05:24 PM
r71's Avatar
r71
I just got the block off plates. I'm taking the air pump out so I took out the ACV blocked and the lines leading to the airpump. That used up 2 plates. Can someone tell me what else do I block off.
Oh, there are 3 connectors coming out from the ACV. Do I need to put resisters on them?
Old Dec 7, 2002 | 05:57 PM
puma's Avatar
canadian monster
the other ones are for AWS, one for the EGR and i beleive one for the double throttle
Old Dec 8, 2002 | 03:22 AM
TomsRX7's Avatar
Not trying to be too much of a smart ***, but match the shapes of the block off plates with the shapes of the various components. Didn't you ever play that game when you were a baby, where you had to put the triangle block in the triangle hole, the round block in the round hole.......
Hehehehe, sorry, but I just had to say it.
As for the plugs, on the ACV, I un-screwed the various sensors out of the ACV body and kept them connected. The better way probably would be to use the resistors. But on the other hand, I think it depends on what computer you have. I've been told that if you have the PowerFC, you don't even need the resistors but I can NOT confirm that.
-Tom
Old Dec 8, 2002 | 11:43 AM
JONSKI's Avatar
5yr member, joined 2001
I simply left those connectors unplugged and did not get any "check engine" light.
You might as well block off the EGR while you are at it, because I think it needs the ACV to do anything useful.
Old Dec 9, 2002 | 08:08 AM
r71's Avatar
r71
Thanks for he input. On to the uim. What do I do with the AWS connection. Risisterors?
Old Dec 10, 2002 | 05:26 PM
JONSKI's Avatar
I'm pretty sure the AWS connector should have a 330-Ohm resistor.
Logan Reinisch
44
Sep 17, 2018 12:20 PM
cook11
V-8 Powered RX-7's
Oct 2, 2015 11:52 AM
jarjarbinks
Sep 25, 2015 11:03 PM
MidnightOwl
Sep 25, 2015 10:24 PM
