what do u thin of the to4e
Old Dec 5, 2002 | 08:55 PM
bigmack000's Avatar
Rotor DEMON !
hey guys just wonder what evryone thingks of the to4e
joel
Old Dec 6, 2002 | 01:29 PM
great turbo setup for the street. carcrazy made over 400rwhp with it. i got a ride on his car, wow !!!
Old Dec 6, 2002 | 01:56 PM
bigmack000's Avatar
Rotor DEMON !
yeah i just bought one for my car and will be putting it on soon but still have to uilt the car up to beable to hold the boost thanks for the input mine is a 1.ooa/r hot side and .70cold ptrim
Old Dec 6, 2002 | 02:27 PM
This is not a hks kit then? hks don't come with those trim with the E
Old Dec 6, 2002 | 03:43 PM
bigmack000's Avatar
Rotor DEMON !
no its not akit i just bough it off of a guy on here and was wondering what the word on them was he said the one i have should do 400rwhp but i just wondering what evryone eles thinks
Old Dec 6, 2002 | 04:54 PM
mjw's Avatar
mjw
A TO4 is a great turbo, with that exhaust housing and a ported motor you can hit 400rwhp.
Old Dec 6, 2002 | 08:11 PM
bigmack000's Avatar
Rotor DEMON !
thaks for the input mjw
Old Dec 7, 2002 | 03:49 AM
TomsRX7's Avatar
Everyone I have spoken to that has it, loves it. I just bought the XS T04E kit for my car too.
-Tom
Old Dec 7, 2002 | 08:11 AM
Maxthe7man's Avatar
Freedoms worth a buck o'5
Bigmack, as Soloracer probably told you, I run the same turbo except with a 1.15 a/r housing.. They are ford truck turbo's usually found on the 7.8litre and the detroit diesels..
My car will be on the road again shortly, however my dynochart is posted here, I was putting down 364 rwhp at 17 psi, they cut off the dyno run at 6600 rpm the hp was still climbing strongly at that point, there is no doubt in my mind if I had gone to 7500 rpm or 8000, I would have seen 300 ft/lbs of torque and 400hp+ at the wheels, all that on a loose s4 motor, with an FD motor and good porting, I am sure 425+ at the wheels is easily attainable...
You probably want to know what my car was like with the TO4E, basically the tach would bury itself instantly in 1,2,and 3 rd gear from 3500 rpm and up, the needle didn't climb like it did with the stock turbo, it actually instantaneously moved from 3500 rpm to 8000, part of that was the pretty intense power, the other part was the fact it was really hard to control the car, the tires spun all the time, even when rolling down an off ramp at 80 km/h's an hour, punch it in 3rd and the tires started to spin, which was kinda unnerving sometimes..
My transmission is making alot of noise since I did the big turbo swap, I need at least 2" wider rear tires to make use of the power, and my rear suspension is now pretty mushy, the car squats down about 4-5 inches on boost..
Its alot of work, and lots of headaches to get the turbo in, and running, I blew my motor, but damn, the last 3 months of driving that car was priceless, I have blown away cars that cost 4 times what my car did to build, and scared alot of people shitless with the open wastegate, which is worth the price of the turbo....Max
Old Dec 7, 2002 | 12:39 PM
bigmack000's Avatar
Rotor DEMON !
hey max thanks i never knew yours was a to4 also i will tlak to oyu when i get back from mexico about the manifold
joel
Old Dec 10, 2002 | 04:56 PM
TomsRX7's Avatar
Maxthe7man,
Sounds like you're having some fun!!! I can't wait to have mine on the road again.
apooch
Sep 4, 2015 10:27 AM
Chris Wilson
Nov 30, 2001 04:00 AM
Chris Wilson
Power FC Forum
Nov 24, 2001 12:19 AM
