My Engine is hot :(
Old Aug 5, 2001 | 07:11 PM
Supermac's Avatar
My Engine is hot :(
Hey everyone, I was driving along with my 88 Gtu, when my little "add coolent" buzzer goes off. I thaught this was odd, since i had just put more coolent in it the other day.
So I pulled off. Coolent looked fine, I added a quart of oil since it was a bit low anyway (but not too low).
The engine seemed to be smoking from the drivers side near the firewall, didnt dig into it and see exactly from where. I didnt let it get too hot, it just started smoking before i turned the car off. I found a ride home, so it's parked in a parkinglot right now.
My best guess is that i need a new thermostat, but i could be wrong. Is there a specific kind that i need to get, what do you guys use?
What else could be wrong? I have no smoking from the tailpipe, so my engine is still good
Any help would be greatly appreciated.
Jameson
Old Aug 5, 2001 | 07:27 PM
HAILERS's Avatar
HAILERS
Are you sure the smoking was not steam coming from the left side? There is a one dia water hose that comes out of the block just aft of the oil dipstick and runs to the firewall . This hose gets oil droped on it and sorta rots away at the engine connection. To be a touch more accurate its located about six inches below the oil filter. Check it out. If not at the block look at the other end going to the firewall. Its a heater hose.
Old Aug 6, 2001 | 12:29 AM
Supermac's Avatar
Thanks, Ill check that out. I know what hose you are talkin about...btw, Left side from what perspective? When you are sitting in the car, left side, or facing the engine from the front, right side?
I got my car home!!! so it's safe in my garage
Old Aug 6, 2001 | 07:09 AM
tesla042's Avatar
Left side of the car, when sitting in it..
Old Aug 6, 2001 | 08:22 AM
Supermac's Avatar
That's what i thaught What's the specific name for that hose again? where's the best place to get it, Mazda?
Old Aug 6, 2001 | 10:28 AM
Supermac's Avatar
I spent some time observing the fan, it seems to be working normally. What im going to do is replace the thermostat and the heater hose on the driver's side.
When you say open the radiator, what should i be looking for?
Also, what's the best way to flush the coolant? What precautions should i take when replacing the thermostat/hose so i dont screw anything up?
Thanks for your help.
Old Aug 6, 2001 | 04:53 PM
Supermac's Avatar
I checked all my lines and stuff today, one of my heater hoses (the one under the oil filter) was completely ripped open. I also bought a new thermostat, so that's my project for tonight.
Thanks for all your help guys, I appreciate it.
Jameson
Old Aug 6, 2001 | 10:00 PM
Supermac's Avatar
https://www.rx7club.com/vforums/show...0564#post90564
Here's an update, everyone please read.
Thank you!
Old Aug 7, 2001 | 06:36 PM
Supermac's Avatar
bump
Th0m4s
Feb 26, 2019 02:04 AM
Microtech
30
Apr 23, 2016 06:37 PM
turbo-minivan
69
Feb 4, 2016 12:29 AM
gtcd
30
Aug 19, 2015 02:44 AM
befarrer
Aug 14, 2015 04:18 PM
