method for remove air pump
Old Dec 2, 2002 | 09:06 AM
jack pang's Avatar
Question method for remove air pump
hi:
i want to remove air pump and install Greedy pully kit and midpipe. If remove air pump, how to disconnect the hose and plug (i need to block it ?) who can show me with photo please.......
Old Dec 2, 2002 | 10:21 AM
Sinful7's Avatar
Hi Jack
hope this will help you.
http://www.rx7turboturbo.com/robrobinette/air_pump.htm
Old Dec 2, 2002 | 02:21 PM
JONSKI's Avatar
5yr member, joined 2001
If you are eliminating your air pump and main catalytic converter, then you should also eliminate your ACV (Air Control Valve).
Can you list all of current mods?
Old Dec 2, 2002 | 04:02 PM
apneablue's Avatar
Hey Jonski, Fancy meeting you here I too am thinking about doing the same thing...is there any drawbacks to leaving the ACV in place when the O2 pump is removed?
The hose job fared well, but not real well...Am still messing with Team Home Depot to see if that's actually what's causing the 11-8-6 boost patter...
Old Dec 2, 2002 | 06:01 PM
JONSKI's Avatar
I don't think anyone knows exactly how the ACV works. Check out pages F-115 to F-123 of the service manual. It explains the ACV. However, I just skimmed it and I couldn't figure it out.
Skeese
65
Mar 28, 2017 03:30 PM
c0rpse
Aug 25, 2015 11:50 PM
86glxNA
Aug 22, 2015 08:54 PM
12abridgeport
Aug 17, 2015 06:28 PM
