Audible boost leak, covered basics
Old Aug 5, 2001 | 05:16 PM
Unhappy Audible boost leak, covered basics
I've noticed I haven't been able to reach normal boost levels for a few weeks. It's clearly not related to the warm temps either. Normally peak boost will max at 12.8 psi, now about 10.2. My greatest concern is the abnormal whoosh under acceleration. I've checked all hosse connections and everything is tight. The blow-offs are also working properly. How common is a deeper intake gasket problem?
Old Aug 6, 2001 | 12:17 AM
wickedrx7's Avatar
check all of your rubber couplings. They might look fine but a lot of times the can get cracked and you can't tel untill you take them of and really inspect them.
Old Aug 6, 2001 | 08:40 AM
Borch's Avatar
I agree. I was having a problem that I thought I checked all of the hoses and connections. I took off the couplers from the hose that feeds from the intercooler to the Y-pipe and there it was. Craked under the hose clamp and facing downward. Just couldn't see it until I took it off.
Good luck!
Old Aug 6, 2001 | 01:42 PM
Actually pulled the intercooler, but I continue checking
n/m
Microtech
30
Apr 23, 2016 06:37 PM
sen2two
AEM EMS
Oct 23, 2015 07:51 PM
