what does it mean if you have low vacuum?
Old Aug 5, 2001 | 01:21 PM
weaklink's Avatar
Resident Retard
I read that you should have 17-19 vac on a stock engine. I only have about 15. I can't find any hoses that are off, but I am having problems with the secondary boost. The primary boosts to 12 or 14. Derek Vanditmars site is ok, but doesn't tell how to fix anything. I know my vac is low, but not why or how to fix it. The car doesn't smoke or idle funny, and there is no fluctuation in the vac at idle. What's up?
Old Aug 6, 2001 | 06:20 AM
KZ1's Avatar
KZ1
you have 12-14 psi on primary with a stock engine?
Old Aug 6, 2001 | 09:08 PM
RICKRX7's Avatar
Are you sure the boost gage is not off 2-3 pounds?
Old Aug 10, 2001 | 07:42 PM
weaklink's Avatar
Resident Retard
Yeah, I have 12-14 on primary, usually 12 sometimes spikes to 14, I et off if it goes there. I have a dp, mp, catback.
Old Aug 10, 2001 | 10:08 PM
RICKRX7's Avatar
Is the idle between 700-750 RPM?
Old Aug 11, 2001 | 02:47 PM
weaklink's Avatar
Resident Retard
yeah I think around 800 and steady after it warms up
Old Aug 11, 2001 | 08:12 PM
RICKRX7's Avatar
If engine compression is not low and the boost gage is accurate,I would check the hoses again.You mentioned secondary boost problems but did not explain.
Old Aug 11, 2001 | 08:51 PM
weaklink's Avatar
Resident Retard
I have not had the compression checked. Think it's ok for the dealer to do?
Bauer778
Nov 4, 2015 04:42 PM
Cameron38
1st Gen General Discussion
Sep 19, 2015 11:45 PM
ZacMan
Sep 19, 2015 09:20 PM
Frisky Arab
Sep 4, 2015 06:17 PM
