whats with my idel??
Old Nov 27, 2002 | 07:46 PM
93redFD's Avatar
whenever I push the clutch in after driving, the car wants to hunt for idel. It alsmost dies on me. Normally i idel at 1100 and now when I push in the clutch it drops all the way down to 300 rpms and then goes up some and back down and hunts. i know this has to be a problem somebody has had before. i just changed the plugs to days ago. does anybody got a idea???
Old Nov 27, 2002 | 07:58 PM
jeff48's Avatar
Rotorally Challenged
Does it run worse than it did before your plug change? Did you accidentally pull the vacuum hose off the MAP sensor while changing the plugs?
Old Nov 28, 2002 | 12:58 AM
93redFD's Avatar
I guess its been doing it for a while, sometimes when I crank up and go, the damn car will just cut off while Im going down the road. Im thinking its the altenator, becuase the guages dim a little when it starts hunting for idel. I know it can also be stavation of fuel@at idel(but why would be filing plugs) the car ran better with 7's filed, than 9s
94Rx-7
Dec 30, 2002 05:31 AM
93redFD
Haltech Forum
Dec 6, 2002 06:00 PM
RotaryMan
Sep 26, 2001 02:08 AM
RotaryMan
Sep 21, 2001 12:38 AM
