Is this trouble???
Old Aug 4, 2001 | 11:16 PM
fcturbo2's Avatar
Is this trouble???
I will be buying this TURBO/Manifold and i would like to know if this is trouble????
Garret To4b turbo, V-trim compressor, P trim turbine wheel with .96 a/r turbine housing, turbo good for around 350 hp
I only have FCON, Bigger pump, FMIC to back it up..
Old Aug 4, 2001 | 11:58 PM
RETed's Avatar
Your stock fuel injectors cannot support that kinda power levels.
How much you paid for that turbo?
-Ted
Old Aug 5, 2001 | 02:37 PM
fcturbo2's Avatar
I will be picking it up up north! (NORCAL)
475 for the turbo
175 for the manifold (HKS)
Can i purchase a TURBO UPGRADE chip from HKS ans install it in my FCON?..
RETED what else can i do to make this turbo not ruin my new motor???..i really dont want to buy HALTECH yet or any of those ECU computers. Isnt the turbo im about to buy just a mild turbo and not of them wild ones???..bro i really need your help.
Also i have a Full Racing Beat exaust. Is it possible to extend the manifold to make it work with the turbo???..
-Ted
Old Aug 5, 2001 | 08:38 PM
RETed's Avatar
It's possible, but it's a PITA if possible.&nbsp Try contacting HKS if you're serious about doing this.
You need at least bigger fuel injectors (and something to control them) and/or raise up the fuel rail pressure via an aftermarket boost-dependent FPR.
720cc fuel injectors from GReddy - $130 each
A'PEXi S-AFC - $450
BDFPR - $200
Yes, you can make an adapter pipe to mate with the existing exhaust.
Mind you, I don't think you know what you're getting into.
Minimally, you'll need:
Stainless steel lines for oil lines to/from turbo - $200
Custom piping for FMIC - $300
FMIC - $1000
I would recommend going with bigger fuel injectors and an A'PEXi S-AFC.&nbsp Reprogram the ECU to get rid of the fuel-cut ($300 from G-Force), and this is a minimal system to get things running...
-Ted
FC3S Timmy
16
Oct 3, 2015 01:08 AM
Rotafuzz
Sep 30, 2015 09:55 AM
Red-Dragon_Akuma
Sep 28, 2015 06:09 AM
blackball7
Sep 20, 2015 08:33 PM
WANKfactor
Sep 15, 2015 07:45 AM
