HIGH REVVING at start up... normal? is mine a bit extreme?
Old Nov 26, 2002 | 02:53 PM
DashKits.net's Avatar
My 93 RX-7 AUTO. when i start it up after a night
of garaged rest () it revvs very high - up to 3000 RPM for at least 15 seconds... then idels down to 1800 or so, then slowly drops to normal.
i have heard this is normal... but sometimes it does it up to 2300 or 2400 RPM which seems more like it.
Does EVERYONE's do this?
is mine a bit extreme? (too high)?
Any input is helpful!
Old Nov 26, 2002 | 02:58 PM
r71's Avatar
r71
Mine does the same. Worse when cold.
Old Nov 26, 2002 | 02:59 PM
spurvo's Avatar
don't race, don't need to
When I start up, the engine speed shoots for 3000. I HATE doing that to a completely cold engine. I tap the throttle JUST A LITTLE BIT (not enough to cause the engine speed to increase) and the idle drops to the 1800 or so. I let it warm at that rpm. The 3K is an emissions thing to immediatley warm the pre-cat and run at hight rpm where unburned HC's are less. I've also read that starting in first gear (but with the cluch in!! hee) will reduce the 3K to the level you are looking for. So it's normal, and defeatable
Old Nov 26, 2002 | 03:01 PM
Rated R1's Avatar
Oji San
Good advice but he has an auto. You can disable the AWS. Look on Steve Cirians site I think there is a how-to there.
Old Nov 26, 2002 | 03:07 PM
spurvo's Avatar
oops! smack me up 'long side the head!!
Old Nov 26, 2002 | 03:17 PM
Scrub's Avatar
bow leggin'
mine also does that but i found out that if you give it a little gas it will calm it down right away.
Old Nov 26, 2002 | 03:24 PM
Street King's Avatar
*** Bless Texas!
Just tap the gas, people should be shot revving it to 3k rpm's on a completly cold engine. It was only for emmisions and does horrible damage to an engine. BOO EMMISIONS, BOO THEM!!!!!!!!!!!!!
Old Nov 26, 2002 | 03:31 PM
rynberg's Avatar
Damn, do people here not even have owner's manuals? There's a section in the owner's manual about the 3k rev at startup, not to mention write-ups on Rob Robinette's and Steve Cirian's sites. Sorry to be harsh but this is basic FD-ownership stuff here.....
Old Nov 26, 2002 | 03:43 PM
SoCalLove's Avatar
Just start your car in gear. No biggie but don't forget you're in gear and let off the clutch .
Old Nov 26, 2002 | 04:19 PM
*** Bless Texas!
He has an AUTO.
Old Nov 26, 2002 | 04:24 PM
SoCalLove's Avatar
Originally posted by Street King
He has an AUTO.
Hehehe....ahhhhh. Well spend the 3-5k to convert it to manual and then start the car in gear. That should fix it .
Old Nov 26, 2002 | 07:26 PM
MikeC's Avatar
Reading the manual for any product is for wusses ;-)
Old Nov 26, 2002 | 07:32 PM
rynberg's Avatar
So is asking for directions....
Old Nov 27, 2002 | 04:09 AM
duboisr's Avatar
Remove the AWS and save the cold start no oil damage . That system is so bad on your engine.
Old Nov 27, 2002 | 09:05 AM
whats the AWS?
and where is it?
easy to remove?
mechanical retard (me)
thanks
Old Dec 16, 2002 | 07:59 PM
RangerJoeEOD's Avatar
Originally posted by DashKits.net
whats the AWS?
and where is it?
easy to remove?
thanks
I would also like this Info
I am having the same problems with my 89 GTUs 5-Speed. Can it be the same finsh? Thanks ( PS i am Not a Retart)
Old Dec 16, 2002 | 08:26 PM
Mahjik's Avatar
Mr. Links
AWS = Accelerated Warm-up System
Old Dec 16, 2002 | 08:28 PM
Mahjik's Avatar
Mr. Links
Arrow
As for removal:
https://www.rx7club.com/forum/showth...ht=disable+aws
Old Dec 16, 2002 | 09:25 PM
ok guys... mine used to do that.. and i know that it's normal... but about 2 weeks ago my engine light came on. i found out it was the egr valve, which is a emission problem. now when i start the car, it doesn;'t jump up to 3k no more, is this because of the egr valve???
Old Dec 16, 2002 | 11:58 PM
futurerexowner's Avatar
Is there honestly a problem with tapping the throttle ever so slightly before it gets to 3k? It takes a second to rise, and when I dont start my car in gear I am always able to tap it before it goes anywhere near 3k. As long as you hit that throttle right when the engine turns over your in good shape... not worth a bunch of work to remove it IMO...
Catlin
Old Dec 17, 2002 | 01:44 AM
spurvo's Avatar
no problem that I have seen
Old Dec 17, 2002 | 03:43 AM
shadow27's Avatar
heh, i second the notion that ppl who didn't even bother researching 7's enough before they buy them to find out about AWS is, should be shot....
Old Dec 17, 2002 | 03:51 AM
BATMAN's Avatar
yea i have that same problem every now and then.. i dont call it a problem either... i just turn the key back..( like turning off the car.. but not all the way..) and i turn it back .. disables the AWS asap
Old Dec 17, 2002 | 10:45 AM
RX7 RAGE's Avatar
Bann3d. I got OWNED!!!
Top Answer: 1
yep, its normal.
Old Dec 17, 2002 | 10:57 AM
cavellm's Avatar
After I put in my Power FC my revs are quite a bit higher at startup than before.
