Check out my heater core
Old Nov 23, 2002 | 03:22 PM
Felix Wankel's Avatar
Super Newbie
It was 28* last night, and I have no heat in my car. I pulled the core today and I can't tell if its the core or the control valve leaking.
Old Nov 23, 2002 | 03:25 PM
Super Newbie
I'm thinking of undoing my byapss and hooking the core up underhood, then starting the car to try to find the leak.
Sorry about posting two threads, this forum is slow as **** sometimes!
PS: Does anyone want a write-up on an 84-85 dash removal? I took all the necessary pictures.
Old Nov 23, 2002 | 03:30 PM
Pele's Avatar
Right near Malloy
Yes, please.
Old Nov 23, 2002 | 03:41 PM
gump's Avatar
heater core
Hey, I'd have to say it's your valve, I've read on here that the heater cores rarely go, and on my GSL-SE it was the valve. Anyway, I ended up buying a whole heater unit from someone with a good valve and heater core allready on it. Here's a picture of what my valve looked like. Isn't it fun taking the dash out
Old Nov 23, 2002 | 03:53 PM
Super Newbie
My car has been idling for the past 20 minutes with no heater box, just the core.
No leaks.
Ugh.
Old Nov 23, 2002 | 04:07 PM
Super Newbie
Re: heater core
I'm going to get a new valve this week, I have some other things to do while my dash is out.
Pele, I will do the write up, but I have to host the pictures on the forum, which is going to take a little while. I have 40+ to upload!
Old Nov 23, 2002 | 04:16 PM
Pele's Avatar
Right near Malloy
Re: Re: heater core
Take your time man. I've gotta get the car running before I worry about the dash and stuff.
Old Nov 23, 2002 | 06:46 PM
79+80_rx-7's Avatar
I would appriciate the write up too! And, it should be archieved when its done.....
What do the valves do?
Thanx, Laterz, Andrew
Old Nov 23, 2002 | 07:46 PM
Super Newbie
When you put the hot/cold selector to heat, it allows coolant to pass though the heater core.
Old Nov 23, 2002 | 08:25 PM
Super Newbie
Here is the core hooked up, with no box. I'm sure you can tell where the heater control valve is
Old Nov 23, 2002 | 11:17 PM
Pele's Avatar
Right near Malloy
Thats a stupid design. One of the few on the 1st gen, I might add. Most cars put those things under the hood. Easy to change when it breaks.
Old Nov 23, 2002 | 11:30 PM
Super Newbie
I know, all the GM products I've had have had them underhood.
The way the pipes run with all those couplers is ridiculous too.
Old Nov 23, 2002 | 11:47 PM
gamble302's Avatar
roadkill hats rock
its under the dash on fox body fords too
Old Nov 24, 2002 | 12:58 AM
Pele's Avatar
Right near Malloy
But that's Ford... We already know Ford products are poorly designed...
Old Nov 24, 2002 | 05:55 PM
diabolical1's Avatar
so if the valve is shot, then does that mean you won't get heat anywhere, or just coming through the upper vents?
my car is sans heat right now, but it comes through the vents for the windshield and down at my feet. what's up with that?!?!? is that the whole core or just this valve-thingie?
Old Nov 24, 2002 | 07:42 PM
Super Newbie
It sounds like you have a problem with the vent selector.
I was going through coolant, so I bypassed the core until it got cold enough to prompt my lazy *** to fix it.
Old Nov 24, 2002 | 08:25 PM
Pele's Avatar
Right near Malloy
Most electronic vent controls have a failsafe that sets it to winter settings (Clear the windshield and melt the snow on your feet) in the event of a failure... It's for safety... Or something...
Not sure about mechanical controls...
Do you have an 84-85 with electronic controls?
The1Sun
Sep 7, 2015 10:21 PM
risingsunroof82
Sep 7, 2015 01:11 PM
Tem120
Sep 7, 2015 09:53 AM
rotor_veux
Sep 3, 2015 07:10 PM
