tps connector unplugged, bad?
Old Nov 23, 2002 | 02:31 PM
puma's Avatar
canadian monster
what would happen if the TPS connector got loose or get disconnected while the car is running? could it do any damage or will the engine simply stop?
thanks a lot
puma
Old Nov 23, 2002 | 02:43 PM
Bill B's Avatar
The computer will go into "limp" mode it will still run just not that good.
Old Nov 23, 2002 | 09:15 PM
puma's Avatar
canadian monster
great, you are sure of that?
if so, that is nice, i broke the nipple that hols the connector in place, it is still tite but it might unconnect so that is why i wanted to know.
thanks
puma
Old Nov 24, 2002 | 07:43 AM
jspecracer7's Avatar
1JZ powered
thanks
puma
HUH? TPS(Throttle Position Sensor) is located on the throttle body. It has a plug on it and the wiring harness connects to it. Where's the "nipple" at?
In any case, I have disconnected the TPS and driven the car around. The only side effects are that the idle went up to 1500 rpms. BUT I have a PFC.
Old Nov 24, 2002 | 10:12 AM
puma's Avatar
canadian monster
well it is not a really a nipple but the little thing that you press when you want to remove it, it is broken.
which means that the little pin that make sure it stays in place is not there anymore. It means that you don't have to press anything to remove the connector.
so it could unconnect by itself
that's what i meant, sorry
betes
Sep 27, 2015 08:25 AM
ZacMan
Sep 19, 2015 09:20 PM
rotary_rx7fc
20
Sep 19, 2015 02:41 PM
