Anyone else with this issue? (2nd gear)
Old Nov 21, 2002 | 11:19 AM
HeatTreated's Avatar
Hi Powr FD's
Shifting to all gears EXCEPT 2nd gear, is smooth. Its like it has two slots to click into before it gets into the gear. Do I need to re-flush some Redline Tranny fluid or is this something you guys have too?
Old Nov 21, 2002 | 12:05 PM
GsrSol's Avatar
Z06 powered FD
Second is a fast gear to go to and alot of people don't have the clutch to the floor when they shift. It's probably the synchro.
Old Nov 21, 2002 | 12:07 PM
paw140's Avatar
Mine does this, only on the 1st to 2nd upshift. I can downshift into 2nd and it's smooth. I'm guessing a worn syncro.
Old Nov 21, 2002 | 12:29 PM
13brv3's Avatar
If I understand what you're describing, yes, mine does it too. 3rd has about the same feel when it's cold, but it's smooth when fully warm. There's never any grinding any any gear, but there are a lot of miles on the trans.
I just put Royal Purple in mine a few weeks ago, and it didn't change a thing. I've got a short shifter, and am waiting for new bushings to install it. That might help, but I'm not holding my breath.
Cheers,
Old Nov 21, 2002 | 01:51 PM
paw140's Avatar
Oh yes, I forgot to add that I got slight grinding on the 1st to 2nd shift before and after I put in Redline MT90. Synthetic didn't help the problem.
Old Nov 21, 2002 | 02:10 PM
rfreeman27's Avatar
same thing with me, most likley syncros
Old Nov 22, 2002 | 01:06 AM
GsrSol's Avatar
Z06 powered FD
I wouldn't suggest a short shifter.
Old Nov 22, 2002 | 01:17 AM
BoostedRex's Avatar
NorCal 7's Co-founder
I fully suggest the short shifter. Unless you like grinding going from 2nd to 3rd gear while racing. But that's just my take on things. Laterz.
Old Nov 22, 2002 | 01:31 AM
BoostedRex's Avatar
Mine's the same way Series7. I think the synchros are going. But we'll find out after the next few races won't we?? Either way, it will give me an excuse to tear into something else and learn how to fix it. It's all a learning experience for me.
Old Nov 22, 2002 | 02:38 AM
reza's Avatar
I am using Redline MT-90 on both of my car.
Both car does that in the morning.
I guess MT-90 a bit lazy to get up on all the gears in the morning...
reza
Old Nov 22, 2002 | 12:17 PM
RICKRX7's Avatar
When the transmission is cold the first to second gear on my FD shifts hard. (no grinding) Once the transmission warms up it shifts smooth. It has always been that way.
Old Nov 22, 2002 | 12:40 PM
Snook's Avatar
Tony Stewart Killer.
I have exactly the same problem
it doesn't grind or anything but you just feel like there is something in the way of it.
I also have the 5th gear sychro problem which grinds like hell until you learn how to put it in smoothly
Old Nov 22, 2002 | 02:24 PM
88and93's Avatar
All of you with these warm-up problems need to use the best fluid for these transmissions BG Products Syncro Shift. I tried some Amsoil crap and the Redline (I think it was the MT-90. I recall they had two choices) and then found out about Syncro Shift and have used it in both cars with great success for the last nine years. Dave at KD Rotary told me a few months ago he has the highest regard for it and all of their products. If your Mazda dealer doesn't carry it try bgprod.com under driveline maintenance. It won't help those that need new syncros, but what usually happens is that they get dirty first (which is the balkiness you feel) which leads to blocker ring wear and syncro failure.
Old Nov 22, 2002 | 03:14 PM
apneablue's Avatar
Something similar happens to me...when I am shifting relly fast from 1st to second or 2nd to 3rd I get a grinding noise...if I double clutch which kinda gives it a bit of time to slip in it doesn't do it as much.
rgordon1979
40
Mar 15, 2022 12:04 PM
Steven_McKinley
Sep 5, 2015 10:48 AM
Murilli
Midwest RX-7 Forum
Sep 3, 2015 09:10 AM
