EGT BOOST Increase
Old Nov 14, 2002 | 05:14 PM
Question EGT BOOST Increase
Theoretically Only ..is it possible to have an BOOST/EGT gauge in your car and basically turn up the boost little by little until you hit an even 1650 deg F and call that your MAX boost ??
..just asking..
Old Nov 16, 2002 | 12:01 AM
duboisr's Avatar
You can dial in your boost then adjust rich or lean to the temt you want, but that does not mean it is adjusted correctly by any means, learn to tune before you pop the motor. find out what boost is safe for your car then tune for that with a wide band o2 set up , not EGT.
Bauer778
Nov 4, 2015 04:42 PM
Clacor
Sep 11, 2015 08:36 PM
t-von
Sep 10, 2015 01:56 PM
High_Carb_Diet
Power FC Forum
Sep 5, 2015 09:07 AM
