stupid me.. doh
Old Nov 14, 2002 | 01:06 AM
cwsttu's Avatar
1.3L is not that small
stupid me.. doh
k im an idiot i know so dont rub it in... as u might know i have my project car im working on, its almost all the way stripped down and the sanding has begun on it, the only thing i have to take out is the engine block and front lower control arms, the rest is just chassis. now i ripped all the wires out compeletly and plan on rewiring only what i need but upon sanding the left side i came across the gas cap.. DOH!!! forgot its electric popped. is it just positive and negative wires that come from it and when both are connecte activates the motor? id hate to just fiberglass over it because i want to make sure its sturdy and rip out all the old gas stuff. is there like an inline fuse that protects it? i would really hate to resort to prying it off because i would no doubt ruin it and have to go thru the pains of glueing metal in there for reinforcements. if this works how im thinking would it hurt to just use a car battery or do i need like a smaller battery. thanks in advance just dont wanna screw it up
Old Nov 14, 2002 | 01:13 AM
DJ!
if u just hook it up long to pop it (bout 3 sec) u wont hurt it! i been there and done that to so dont worry your not the 1st and u wont be the last!
Old Nov 14, 2002 | 03:16 AM
cwsttu's Avatar
cool gotcha ill do that tommorow thanks
Old Nov 14, 2002 | 09:08 AM
MyRxBad's Avatar
EliteHardcoreCanuckSquad
Remove the rear interior panel and then pull the level back by hand.
Old Nov 14, 2002 | 09:51 AM
nosajwrx-7's Avatar
Rotax, Rotaries & Turbos
I am not sure how it is set up, but, my old '86 Subaru wagon's didn't work and I used to just slide my key between the gas door and body and push the little button in. I never scratched it or anything. It worked perfect every time. Might work.
Old Nov 14, 2002 | 09:54 AM
rotary emotions's Avatar
HEAVY METAL THUNDER
like myrxbad said: just open it manual. It's easy enough, I've done it a few times, all you do is removing the trim, and then you can reach the lever and open it. Don't need a battery or anything.
Old Nov 14, 2002 | 01:33 PM
RotorMotorDriver's Avatar
Seven Is Coming
If you do put the battery in, make sure nothings gonna short out anywhere else...Like the cable that goes to the starter and what not (ask me how I know).
~T.J.
Old Nov 14, 2002 | 01:39 PM
jeremy's Avatar
male stripper
actually if you're fexible, you can reach it without removing the panel. power to the triple jointed people.
Old Nov 14, 2002 | 05:40 PM
Pele's Avatar
Right near Malloy
Due to sitting around, the solenoid in mine rusted so that it wouldnt pop. I had to use a pocket knife to pry it open. If youre careful, you wont hurt anything. Little squirt of WD-40 and I was back in business.
befarrer
15
May 19, 2022 10:44 PM
vish86
Interior / Exterior / Audio
Oct 1, 2015 11:53 PM
Donald Hampton
Sep 17, 2015 03:13 PM
Auroraw0lf
Sep 15, 2015 04:55 PM
