coolant seal fix in-a-bottle.....
Old Nov 13, 2002 | 06:16 PM
bajaman's Avatar
Constant threat
Well, out of totally having nothing to lose, I loaded up my car with PRESTONE SUPER SEALER (its in a metal can...never had seen it before) two nights ago and drove around for a half hour or so. It took forever to get the car started, and after the treatment and the drive the idle hunted and it ran kind of rough at low rpm.
So I parked it with a sense of "nothing ventured, nothing gained" and set about contacting various engine rebuilders. (The PINEAPPLE large street port is looking REAL good, by the way! )
So yesterday I get home from work, go out to start the car expecting a battle like the night before and to my total ******* amazement, it fired right up!
So I drove around for a while, taking it really easy, it seemed to be fine although I noticed I could hear a gurgling in the heater core on hard acceleration.
So I parked it last night, checked the coolant level after it cooled, had to add just a bit.
Then tonight when I got home, I went out and....it started and ran just fine again.
I have been out for about an hour, it seems to run fine.
I know, I know....this is only a stop-gap measure for now, but at least the car is not DEAD dead like it was before. Hell, the coolant level was right on the mark....didn't have to add a drop.
******' freaky, it is......
Old Nov 13, 2002 | 06:22 PM
spurvo's Avatar
don't race, don't need to
till you gotta clean when you put in the rebuild.
J/K (kinda...) way to go. Now you can drive it REALLY hard, cause you have to rebuild anyway, right?
Old Nov 13, 2002 | 06:26 PM
Goober's Avatar
de doober
I have some luck with those fix a leak in a bottle stuff in the past... I might give it a try in my Delorean since its leaking a little coolant on my driveway right now. Good luck with the rebuild...
Old Nov 13, 2002 | 09:00 PM
rajeevx7's Avatar
2 FD's since '98
i vouche for that. i thought i had a problem, then used the sealer...
now its been sooooo long and i havnt had to add any coolant, i cant remember if i ever really had a problem!
Old Nov 13, 2002 | 09:11 PM
Well I didn't have good luck with that stuff.
It lasted only a month.
now I need new motor.
Old Nov 13, 2002 | 10:32 PM
I would call that at least 'fairly good' luck. At least you got an extra month out of your engine.
Brandon
Old Nov 13, 2002 | 10:54 PM
artguy's Avatar
WTB** Very Low Miles 94-95
a month of driving aint worth the mess inside your motor and now nicely sealed radiator and turbos.
do it right or ya pay for it later.
j
ZacMan
Sep 19, 2015 09:20 PM
ZaqAtaq
Sep 5, 2015 08:57 PM
