Just installed my t78. Have a few questions and comments :)
Old Nov 12, 2002 | 03:17 PM
1point3liter's Avatar
Twin Turbo LSX
Thumbs up Just installed my t78. Have a few questions and comments :)
First off I have to admint I'm very happy with the initial results. The car really doesn't come alive untill 4-4.5k but once it does definately a fun ride. The open wastegate dump sounds incredible. Well incredibly loud anyway... lol... We'll see how long I think it's cool.
I've only really have one problem, it's the common profec B / t78 kit boost control problem.
I can't seem to get the profec to control boost. I've hooked it up like sugested in the manual, and I've hooked up it like an internal wastegate.
Hooking it up as in the manual just lets the boost build. I let out of the throttle and my peak hold kept showing 1.0, 1.1, 1.2. No telling how high it would have gone if I was full throttle and stayed in it. With the profec unhooked I can keep stay at 9.5-10psi.
Anyone have anymore suggestions?
Old Nov 12, 2002 | 03:30 PM
nocab72's Avatar
03 Cobra Killer
https://www.rx7club.com/forum/showth...hreadid=126636
Old Nov 12, 2002 | 05:16 PM
rx7tt95's Avatar
Photo Diety
What does your boost response look like? Are you seeing 10+psi at 4K rpm or is that when it goes ballistic?
Michel
Old Nov 13, 2002 | 10:45 AM
Twin Turbo LSX
I'm currently hold 9.5/10psi to redline. I'd say easily have 10psi by 4500 in 4th. Not positive about 3rd. I'll check when I go to lunch.
Old Nov 13, 2002 | 10:48 AM
Twin Turbo LSX
Well, I am going to trying setting up the profec like this pic. Anyone have any idea on what dip switch settings to try?
Thanks!
Old Nov 13, 2002 | 11:20 AM
vosko's Avatar
Just Call Me Terminator!
my car is pretty responsive... with the T78!
Old Nov 13, 2002 | 11:35 AM
I HAVE A MANUAL BOOST CONTROLLER FROM WHEN I HAD A T78.I HAD 22LBS BY 5500-6K RPMS.AND ITS FOR SALE
Old Nov 13, 2002 | 11:56 AM
Twin Turbo LSX
Actually I think I'm closer to 4k in 4th.
Old Nov 13, 2002 | 12:04 PM
vosko's Avatar
i get 10psi around 4k rpm... i never actually looked hard. although i could check my datalogs... that would work. god i love my haltech e6k
Old Nov 13, 2002 | 01:45 PM
rx7tt95's Avatar
Photo Diety
That sounds about right...At first I thought it might have been a wastegate problem. I'm still not 100% sure though. More testing needed.
Michle
Old Nov 13, 2002 | 02:18 PM
Twin Turbo LSX
I'm still a little up in the air about hooking up the profec. I seem to have tried a lot of the different combos. Anyone have anymore imput on boost control with the t78 kit.
I've got the lines run to the top and side ports on the gate.
Which line off the wastegate hooks to the out on the profec? Do I need to hook the other line off the wastegate to the intake manifold? What are the proper dip switch settings for the setup.
When the profec is hooked up properly and I turn it off, I should be getting 10psi right? So far if I hook it up like the book says I can't keep boost down wether it is on or off. Other methods show the same results or sometimes I can't get more than 9.5-10 with it off or on.
Sorry for this repeat question, just need to gain control of my boost.
If I want to hook up a needle valve, I would assume it would go inbetween the intake manifold and the top port on the greddy wastegate, correct?
Thanks!
Old Nov 13, 2002 | 04:38 PM
rx7tt95's Avatar
Photo Diety
I have an AVC-R so I can't comment directly on the Profec but I would suspect that the hook up is similar. The top port on the wastegate goes to my AVC-R solenoid out while the side port goes to the pressurized tube just after the compressor discharge. The "in" port on the AVC-R solenoid goes to the same pressurized line. The dip switches on the back of the PRofec, I have no idea on that one...
Michel
Old Nov 15, 2002 | 03:55 PM
Marcel Burkett's Avatar
Think of it this way , the pressure line off the turbo discharge is to be connected to the port below the diaphragm and is trying desperately to open up the wastegate by pushing against the spring and the diaphragm (within the WG) , to counteract this the boost controller is also pushing against the diaphragm and helping the spring keep the WG closed , when the gate is to open the controller reduces the pneumatic pressure to the WG and vents it to atmosphere , allowing the gate to be pushed open .............., so the bottom line is , connect the lower port of the gate to the highest soutce of pressure (turbo discharge) and tee off the line and connect to the "IN" port on the actuator , connect the "out" from the actuator to the top of the WG and the third port is a MAP sensor port so the controller can know whats happening , once hoked up right its should just be a matter of PROPERLY programming the controller .
ItsJBohmzB
171
Apr 24, 2017 01:11 PM
gabescanlon
Interior / Exterior / Audio
Aug 11, 2015 05:59 PM
