Kaazzzz Hell !&*^#%@@!!
Old Nov 11, 2002 | 07:43 AM
Well boys and girls I think I am about to just throw in the towel and get myself a Buick wagon !!
<I would to ask the mods in this section of the forum to please allow this one in here as it's a mod that most big HP guys would be running in their cars..and there are quite a few guys doing this one ..please.>
My stock R1 LSD was torn up so I got myself a KAAZ LSD with a set of 4.33 gears. Put it all together and now the pinion is sitting too low in the crown wheel, I painted the CW in yellow and the Pin in red and rolled them to see how they mated together. I tried adjusting the crush washer on the pinion and as best as I can to get the spacing but that's it. only other thing that can be done to adjust the backlash and spacing of the teeth are the two spacers or shims on either side of the LSD itself and it's bearings. ..sure enough unlucky me.. I need shims now.
Presently, one shim is 246 thousands and the other one is 276 thousands.. the replacement shims must total the same width but they each must be of different thickness such that the LSD will move off center causing the crown wheel to move back away from the pinion teeth to get the backlash required and the spacing of the teeth of both.
NOW, Where the heck do you get shims other than the stock ones ??
..and NO, you can't grind off one side to move it because the bearings will not be properly loaded.
Please Advise,
3G7
Old Nov 11, 2002 | 09:35 AM
Bacon's Avatar
IRS 4 Life
i thought the stocks came in varing thickness...last time i saw one being installed dave had a whole box of oem mazda shims...so they do exist
Old Nov 11, 2002 | 12:33 PM
AH ! Now to find a number for KD !
Thanks !
3G7
R.O.D
34
Jan 6, 2016 12:09 AM
R.O.D
Rtek Forum
Sep 23, 2015 01:15 AM
