Removing Air Pump
Old Aug 2, 2001 | 10:07 AM
ejmack1's Avatar
Lawn Ornament
Removing Air Pump
Ok, anyone have a good walk through, things that needs to be blocked off, taken out, replaced, whatever... Gettin ready to order teh pulley kit and just wondering what else i will need... Thanks
Old Aug 2, 2001 | 03:07 PM
yomamasmama's Avatar
3/4" rubber plug
remove intercooler pipe that crosses between smog pump and alternator
loosen and remove smog pump belt
3 bolts hold the smog pump, take them out
unplug connector
wiggle smog pump out
the pulley replacement should be easy, you just have to loosen the bolts on pulleys you'll be replacing
Old Aug 2, 2001 | 03:21 PM
ejmack1's Avatar
Lawn Ornament
Thanks,
i take it you have done this before, do you need air tools to get the other pulleys off, hows the idle, do you use a resistor, how many hoses need to be plugged....
Old Aug 2, 2001 | 04:20 PM
black99's Avatar
Lurking..................
check this site out, do all of this, and then add your pulleys.. and of course no need to look for a 30" belt because a belt comes with your pulley set...
http://www.rx7turboturbo.com/robrobinette/air_pump.htm
Skeese
65
Mar 28, 2017 03:30 PM
c0rpse
Aug 25, 2015 11:50 PM
86glxNA
Aug 22, 2015 08:54 PM
12abridgeport
Aug 17, 2015 06:28 PM
