Backfiering when.......???
Old Aug 2, 2001 | 08:56 AM
LLman's Avatar
Lucky owner
My 87 N/A backfires : when I let off the throttle & the Gear is in.
It's almost impposible to brake with gear in because the backfiering & car started to shake.
Is tho problem in air pump or something else..
LLman.
Old Aug 3, 2001 | 01:20 PM
HAILERS's Avatar
HAILERS
I'd check the tps setting and also look to see if the oxygen sensor is functioning. Too much gas at the wrong time. Just another guess. Got a digital meter? Edit....also how stock is your car. Parts removed? Parts added?
Old Aug 3, 2001 | 02:48 PM
BlackRx7's Avatar
Daily Domestic Killer
Heh, your lucky my car backfires all the time, I don't mind though cause at night you can see sparks. plus I have all emissions removed.............
Old Aug 3, 2001 | 05:28 PM
CanadianRX7's Avatar
yea but his car shakes when it does it!!! that would suck!!
maybe try running your car on higher octane gas if u dont have flames i use 91 or 89 octane
Old Aug 4, 2001 | 12:20 AM
MasteRX's Avatar
More Than Meets the Eye
Could be airpump, also could be Air Control Valve. The ACV controls exhaust gases to prevent backfiring. To do a check on this, you need a Mazda repair manual, and folow the procedures in there.
rotary.works
11
Sep 8, 2009 03:42 PM
