Clutch Not releasing when I press Pedal....
Old Nov 9, 2002 | 03:49 AM
ejmack1's Avatar
Lawn Ornament
It started last night after a long night of runnin her hard... The throw out bearing is still in tact with the ring on the pressure plate... The pedal still feels like its there, but every now and then when i press the clutch in, it wont disengage. I am starting to think that this is the cause of my third gear grind all the time, and 2nd gear when im runnin it hard. Because it only seems to grind when this is happening.
Would my slave or master cylinder be bad? or clutch pedal not adjusted properly
Old Nov 9, 2002 | 07:17 AM
rxrotary2_7's Avatar
slave or master cylinder went south. cant realy adjust a hydrolic system.
start with these 2. look around for brake fluid leaking. sounds like one of the 2 above.
Old Nov 9, 2002 | 10:11 AM
ejmack1's Avatar
Lawn Ornament
there is no brake fluid leaking
Old Nov 9, 2002 | 12:01 PM
is the half a the resivoir for brake/clutch still full on both sides?
pull the slave off and take a look at it. is it functioning?
Old Nov 9, 2002 | 12:04 PM
ejmack1's Avatar
Lawn Ornament
It is full on both sides... ill check the slave later to make sure, but im almost certain it is.
Old Nov 10, 2002 | 02:01 AM
rx4ur7's Avatar
Is there still a little play in the foot pedal(1in up and down)if not theres an adjustment on the rod off the back of the foot pedal,I think its 2 twelves,... try adjusting this and it may buy you some time. Lack of fluid or a bad slave is unlikely becuse when these 2 happen it usually will have a prob in-gaging and you cant seem to get it dis-engaged,which prob is disc and p.plate trouble.
Old Nov 10, 2002 | 10:50 AM
ejmack1's Avatar
Lawn Ornament
THere is the same amount of movement on the disc and plate, so im pretty sure its not that, ill give the adjustment another try, i know for a fact its way off,
Old Nov 10, 2002 | 04:58 PM
rx4ur7's Avatar
I mean up and down play on the pedal itself. There should be 1" of play on the pedal when you start to push it in with your foot.
Old Nov 10, 2002 | 05:17 PM
all2muchfun's Avatar
I had something like this go wrong with my tolan after "racing" in it the clutch felt like it would go out no pressure what so ever. Till it got to the very bottem. It was my clutch master cylinder. I've also heard that a kids flywheel was loose in his car and had something like the same problems.
Old Nov 10, 2002 | 06:40 PM
ejmack1's Avatar
Lawn Ornament
I hope the flywheel isn't loose! I tightened the **** out of that ******!
I drove the car tonight after getting my differential in, and it seemd fine... hmmmm who know! lol
Old Nov 10, 2002 | 07:38 PM
maxcooper's Avatar
WWFSMD
My guess is that the clutch hydraulics are bad, the slave cylinder is loose, or you broke the clutch fork.
You aren't leaking fluid, so it isn't the hose. Though you can get SS ones for $20 from Mazdatrix if you want to do some upgrades while you are in there.
If the slave isn't simply loose, it is probably one of the cylinders or a broken actuator arm. I don't know anything about the arm/fork, but... You can get a master cylinder rebuild kit for not too much money, and it is not very hard to rebuild. The slave cylinder can also be rebuilt, but they are pretty cheap as remans, so that may be easier.
If you replace the hydraulics, get a pressure bleeder from http://www.motiveproducts.com/ or just leave the slave bleeder screw open a bit for 24 hrs. I had a hell of a time trying to bleed mine with a vacuum bleeder and it just didn't work. I left it open a bit and it was much easier the next day. I have since used a pressure bleeder for the brakes (it rules!) and I imagine it would be great for a fresh clutch installation, too. Speedbleeders don't work with a lot of air in the lines and my clutch Speedbleeder did not fit in my reman anyway.
-Max
Old Nov 10, 2002 | 07:56 PM
ejmack1's Avatar
Lawn Ornament
ill pick up the master cylinder rebuild kit, i just recenty rebuilt the slave cylinder
Old Nov 10, 2002 | 11:10 PM
you might look into shimming your flywheel. i had a mustang come into my shop and after a flywheel resurface and new clutch, it wouldnt disengage. never seen anything like it. i would try the $10 fix first.
Old Nov 10, 2002 | 11:39 PM
SnowmanSteiner's Avatar
Ga-nome liberator
Don't know if this will help much but, my truck did the same thing, it wouldn't engage or disengage. It turned out that the bracket in the firewall that held the clutch line in had come out. All I had to do was put it back into it's hole in the firewall and it was fine. I hope it is as simple as that and nothing major. Good luck.
- Steiner
Old Nov 11, 2002 | 07:05 AM
i have broken a fork in the past. if he did this, he would hear some nasty noises. mine (pieces of the fork) actualy went through the bell-housing after cracking in 3 places. this would also cause the *pin* in the slave cylinder to come out thus causing a loss in fluid. no?
Old Nov 11, 2002 | 11:24 AM
ejmack1's Avatar
Lawn Ornament
yes the pin in the slave would come out and leak, i know its not the fork, because i can see it moving the throw out bearing. I have been driving the car the apst two days, without any other problems. Could it have just been from me running it hard for a good 4+ hours . Does the fluid heat up at all?
carid
Vendor Classifieds
Sep 10, 2015 09:24 AM
