Coil Over Problem?
Old Nov 5, 2002 | 03:18 PM
Coil Over Problem?
I have just fitted a set of Bilstien Coil overs to my T2, the ft tyres seem to be rubbing on them? even though the Stock struts used to clear the Tyres.
Could i have fitted them to the wrong sides (ie if they where handed?),Wrong ofsets on the wheels (that are 18"x8 with 225/40/18's on) or possably the wrong struts for my car?
Are Gen 2's suspension all basicly the same?
Thanks.
Old Nov 5, 2002 | 06:50 PM
ARD T2's Avatar
The problem Grizz is that the lower spring perch is likely hitting the inner rim lip. Unfortunately that can't be helped unless you get a coilover that allows you to lower the vehicle independently of the spring preload.
You probably have it right. That's just how they are sometimes.
Sorry, Rishie
Old Nov 6, 2002 | 07:05 AM
What is the best way of sorting it? Could i fit a spacer to the rim?
From what i can see the rim protector on the Tyre seems to just be catching the spring platform (as you say) it needs to move max of 10mm? (the problem is i dont have the ft planels fitted at the moment so i cant see if i have 10mm to play with?)
Old Nov 8, 2002 | 12:03 PM
Unhappy
No One?
Old Nov 8, 2002 | 02:05 PM
apexkw's Avatar
in slow, out fast!
you could try a spacer if you want. you also might have to get longer wheel studs.
SakeBomb Garage
Vendor Classifieds
Sep 7, 2015 03:44 PM
SakeBomb Garage
SakeBomb Garage
Sep 7, 2015 03:32 PM
SakeBomb Garage
SakeBomb Garage
Sep 4, 2015 05:20 PM
SakeBomb Garage
Vendor Classifieds
Sep 4, 2015 05:19 PM
