13b vs 13b turbo ?????
Old Nov 4, 2002 | 10:34 PM
zaridar's Avatar
35r 13b first gen
Is a second gen 13b non turbo capable of having just as much hp as a TII if you get an aftermarket turbo and add it on?
How much hp can you get from a non turbo stock second gen engine if you do turbo it and port it??
Thanks
Joshua
Old Nov 4, 2002 | 10:37 PM
RotorMotorDriver's Avatar
Seven Is Coming
As far as I know, the answer would be yes, but only if you swapped out the rotors for low compression rotors from a turbo also, in which case then you would just basically have a 13BT with an aftermarket turbo. If that makes sense.
~T.J.
Old Nov 5, 2002 | 01:26 AM
djmickyg's Avatar
RotorMotorDriver is right, the TII has low comp rotos and with the stock non turbo engine u would be able to run no where near as much boost as the TII would, unless u rebuilt the stock motor..
and also are the dowls in the TII stronger compaired to the stock non turbo??
Old Nov 5, 2002 | 03:42 AM
Its been my experience with other cars that stock intercoolers aren't all they are cracked up to be either, so if you get a high quality aftermarket one you could potentially have more HP than a 13BT.
Old Nov 5, 2002 | 03:44 AM
rotary emotions's Avatar
HEAVY METAL THUNDER
I'll tell you in a few months. I'm going to rebuild a 13B, port it, use TII rotors, TII rotorhousings (easier porting), and TII turbo for a start (might use other turbo later).
Old Nov 5, 2002 | 11:06 PM
HIMNI Racing's Avatar
Rick James
Juat get a TII motor with a s5 turbo. It's just ezer.
Old Nov 6, 2002 | 09:48 PM
zaridar's Avatar
35r 13b first gen
What about if i rebuilt the non turbo engine? What is the difference between low com rotors and regular ones is the pocket bigger or what?
Also what is the cheapest good quality rebuild kit you can find for my second gen 13b that i plan on turbo charging..
thanks
Joshua
Old Nov 6, 2002 | 10:11 PM
onepointone's Avatar
i say what i want
maybe you should go talk to some of the second gen guys with the hooked up t2's
plus, why would you go through all that trouble of rebuilding an n/a when in the end, you will have a t2 motor. it would be alot cheaper/easier to just got with a t2 motor in my opinion
Old Nov 6, 2002 | 10:27 PM
85TIIDEVIL's Avatar
ALLROTOR
Here's an idea.... Build a N/A motor/setup with TII rotors and a 500 shot of NOS...
Old Nov 7, 2002 | 10:21 PM
zaridar's Avatar
35r 13b first gen
What about rebuild kits? I can seem to find anything on the searches any of you rebuilt your engine? What kit did you use?
thanks
Joshua
Old Nov 7, 2002 | 10:28 PM
zaridar's Avatar
35r 13b first gen
thanks
Joshua
Old Nov 7, 2002 | 10:32 PM
Project84's Avatar
Open up! Search Warrant!
thanks
Joshua
Try these sites
www.mazdatrix.com
www.atkinsrotary.com
Old Nov 8, 2002 | 04:55 AM
Gatorgunner's Avatar
thanks
Joshua
you can say that again
Machupicchu
Aug 17, 2015 08:27 PM
KAL797
Test Area 51
Aug 11, 2015 03:47 PM
